Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Installed new opener and everything worked properly. 2days later the safety sensor doesn't work. The amber and green lights are not lit and the door won't go down. This is a Chamberiain 1/2 hp chain drive. The blinking indicator says it's the safety sensor. Did they short out or did a circut board go?
    President:
  • 3,197 Answers
If you haven't yet, double check the wiring on the back of the motor unit. A wire could have broken or just come loose. If your opener is new it will be in warranty.
Posted on Sep 28, 2009
Memorex 3202-3223 dvd burner disc tray won't open
Try reseating the DVD drive so it makes proper connection.
Mar 05, 2012 | Computers & Internet
Frigidaire Gallery Commercial Heavy Duty GAS DRYER Model GLGR331AS1: gas lights and dryer operates for approximately two minutes. Then the gas goes out and approximately 1 minute later the igniter comes...
The flame sensor, ignitor, and coils all are wired together in a complicated circuit so that the coils will not operate untill the ignitor is out of the circuit and is screaming hot. If the ignitor is open or bad the coils will not operate because the ignitor becomes like a thermocouple when screaming hot. So if the ignitor is working and the flame sensor is working properly AND the dryer will work some and then quit, I would suggest to you that the coils are aged and when they get aged they tend to fade and die when used once or twice. It is an aggravating thing to diagnose. Replace the solenoid coils and rock on dude!
Nov 19, 2011 | Frigidaire GLGR331A Gas Dryer
It won't go on. Nothing, no noise at all. Does not work
Can you check the safety switches. There are usualy a couple of spots that will cut off power to machine if the bowl is not installed properly. One is at the bottom usually a pin type of setup that tells it the bowl is installed and then a lock on topto make sure the top is on properly. Check to make sure A it is installed properly B thatnone of thos pins have cracked therefor not doing it's job properly
Dec 14, 2010 | Oster 3200 Inspire In2itive Food Processor
My garage door opens fine by pushing the button once, but won't close unless I hold the button down through the whole down motion.
The problem is with your safety "eyes" on your system. I bet the lights on the opener click rapidly once in awhile as well. Make sure that both lights on safety "eyes" sensors are on (one of them is amber and the other is green). If not, check the wiring onto the opener - white wire should go to white and gray to gray. This system will not operate properly if it cannot sense the proper functioning of the safety "eyes" sensors.
Oct 07, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Silverado 2000 5.3 4x4 gas gauge not working properly. Listen I have installed (2) new fuel pumps and fuel level sensor. I installed a insturment cluster. I ran a new ground wire from fuel pump to...
there are 4 wires at the sender - and 3 wires for the vapour sensor-the two heavier wires are for the pump and the lighter wires are for the guage-the lighter purple wire should have 5 volts on it-if not you may have a wire or computer problem-th guage is an input to the pcm(computor) under the hood and then is transmitted via comm. line to the cluster-if the rest of the guages work in the cluster you need to look at the pcm or wiring to the tank
Aug 16, 2010 | 1999 Chevrolet Silverado 1500
Need help with craftsman 315 opener. this is a new install and the safety sensors are not working properly. even when they are not aligned properly, both the green and amber lites are lit solid,should...
Check to make sure you have them properly connected at the motor. The solid white wire from each sensor goes to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman 1/2 HP 139.53985
Check the wiring. when you installed the new sensors did you run all new wire? Sometimes during an installation the installer staples the wires to the wall then across the cieling to the opener. Sometimes the stapler will pierce the wires or be too tight and over time a short will occur. If all the wires are exposed (you can see them) slide them abit and see if theres a really tight one. (Helpfull if you have an assistant stare at the sensors to see if something happens). If thier buried in the wall then run new wires. Sometimes the drywallers will hit a wire with a screw when thier doing thier job.
Jun 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
71 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
