Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can you lay a lcd sharp 82u flat
Can you lay a lcd tv flat like when you are to install the stand?
    Novelist:
  • 192 Answers
Yes.
We work on them face down and even store them in our shop like that. We've never had a problem.
It is never recommended to transport them laying down.
Did this answer your question?
Posted on Dec 18, 2007
I want to put my lcd tv under my bed in its box till i move out will this be ok ?
Posted on Jan 08, 2008
How to remove the base from your flat screen tv
There are 4 holes on the back of the TV just above where the neck of the base is. Lay the TV face down on something soft that will support the weight and remove those 4 screws. pull the stand off the bottom of the TV.
Jun 16, 2014 | Sharp LC46SB54U 46 in. LCD TV
How do you install tv stand
Are you talking about the stand that the unit came with or a wall mount? If you are talking about the original stand the unit came with all you need to do is lay the TV down on a flat surface making sure that it does not damage the LCD display ( the display is very delicate and can break very easily). You can lay the TV on a bed, carpeting or something that will not cause damage to the screen. Remove the 4 screws from the rear side bottom of where the stand goes unless the screws come inside a plastic bag. Slide the stand into the bottom of the TV and replace the screws to secure it in place. Then stand your TV up, make your connections and enjoy!
Apr 06, 2012 | Dynex 32 in. LCD Flat-Panel HDTV
Cannot remove stand from sharp aquos 52 inch lcd tv
there are 4 screws on the back of the TV just above the stand that have to be removed before the stand can be separated from the TV
Jan 26, 2012 | Sharp Aquos Televison & Video
Sharp aquos lcd colour tv model lc52le700e i need an orginal stand for this tv where can i get it if possible at all
I found this available on www.encompassparts.com.
log in as a guest, enter your model number, the first three parts listed for this tv are,
Stand support, Stand base assembly, and stand screws. Total cost for the three items $ 108.00
I checked E-bay and found none.
Jul 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Not sure how to remove bottom stand from the tv
Lay the tv down to flat cushine surface like a bed maybe.Take all the tv Philip screws out of the base stand,give it a little tuckles like fordward or backward of the tv base stand will come wright out.
Jun 17, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
How do i remove the stand that allows the tv to stand up?
Generally there are 4 screws in the back near the center-bottom of the TV. Lay your TV down on a flat surface and remove those screws then slide the bottom out.
Mar 30, 2011 | Sharp LC46SB54U 46 in. LCD TV
How can i get the stand off of the tv to hang on the wall?
Before detaching the stand, unplug the AC cord from the AC INPUT terminal. Before performing work spread cushioning over the base area to lay the TV on. This will prevent it from being damaged.
With the hex key that came with the television stand remove the four screws from the bottom back of the television and remove the stand.
If you also wish to remove the post from the stand base unit you can remove the four screws that attach them.
Jan 03, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Have 32 flat screen tv, want to transport it to new location, will take 3 days, can i lay in on its back?
I would not recommend you ship it on its back you might break the screen. I would ship standing up.
Good Luck and please rate 4 thumbs up and please leave a testimonial
Oct 03, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
740 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
