Question about Dell Latitude C400 Notebook
Diagnostic Startup Is there a sequence of keys to start a diagnositc startup on powering up this computer?
  • Tomas090 Dec 18, 2007
    Sorry, should have posted I am running Windows XP
    No problem with windows, actually no problems at all!
    Most of the newer Dell computers allow you to hold the function key at power on and internal diagnostics (All hardware etc) runs a diagnostic tool
    I was hoping the older 400 might have something similar
  • 383 Answers
Linux and UNIX pine information -d debug-level, ( Output diagnostic) info at debug-level (0-9) to the current ... (comma separated list of) keystrokes which Pine should execute (on startup).
God Luck.............Please dont for get to Vote/ Thank You.
Posted on Dec 18, 2007
  • sheila skaggs Dec 18, 2007
    CHECKLIST
    Troubleshooting Windows XP startup problems
    First of two parts. (Click here to read Part 2.)
    One of the most common troubleshooting problems in Windows XP is the failure of a system to start up properly. These failures can be caused by a number of issues, including poorly written or malicious software, faulty device drivers, hardware incompatibilities, corrupt or missing system files and incorrect system configurations. Determining the source of the problem, and fixing it, is easier if you use a methodical, step-by-step approach.
    The first question that should be asked when troubleshooting startup problems for Windows XP is: What changed? If a user has just loaded new software, added new hardware, updated drivers or made a change to the system configuration, you should assume this was the cause of the issue until you have ruled it out by undoing the change. This includes operating system updates from Microsoft, which have been known to cause an occasional issue. If a recent change is not a potential cause of the startup failure, you should suspect hardware failure, viruses or malicious software or data corruption. Troubleshooting the issue will depend on the point at which startup fails. The further along in the startup process the failure occurs, the easier it is to troubleshoot and repair.
    If the workstation starts normally and fails after logon
    The problem may be related to a user profile, network logon script, application, driver or service. If the system produces an error message or blue screen, copy the message and check Microsoft's Knowledge Base to see if it is a known issue and if a workaround or patch exists. If the issue is not in Microsoft's database, try searching technical discussion groups, third-party sites or Usenet.
    If you do not receive an error message, and the system simply hangs or continually restarts:
    1. Try logging in with a different account. If this resolves the issue, the problem may be related to the user's profile, account profile, permissions or group policy settings. Start by checking the event log on the local machine by using the Microsoft Management Console.
    2. Try logging with a local account. If this resolves the issue, the problem may be related to authentication, networking, logon scripts, drive mappings or related issues. Again, the workstation's event logs may provide additional clues to the cause of the failure.
    3. Try booting into Safe Mode by pressing F8 during startup and choosing Safe Mode from Windows Advanced Options Menu. Safe Mode loads Windows with a minimal set of drivers and services. If the problem still occurs, it is most likely related to corrupt or missing operating system files or hardware. If the problem does not occur, it is likely to be a driver, service or startup application issue.
    4. Enable Bootlogging by pressing F8 during startup, and choosing Enable Bootlogging from the Windows Advanced Options Menu. Bootlogging is a diagnostic feature that will list every driver the operating system tries to load. It creates a text file named Ntdtlog.txt in the Windows directory that can be opened with Notepad. You can also check the status of your hardware devices using Device Manager, which can be accessed via the Microsoft Management Console, or by right clicking the My Computer icon, clicking Properties, selecting the Hardware tab, and clicking the button labeled "Device Manager." From the Device Manager menu, you can add, remove or disable hardware, as well as update or roll back drivers.
    5. Perform a clean boot. A clean boot is similar to Safe Mode, except that it offers greater control of the boot process. Here are the steps:
      • Logon onto the workstation using an account with Administrator privileges.
      • Click Start, click Run, type msconfig in the Open box, and then click OK.
      • On the General tab, select Selective Startup, and clear the checkmarks next to the Process System.ini, Process Win.ini File, and Load Startup Items. (Note: You will not be able to clear the "Use original Boot.ini" check box.)
      • Next, click the Services tab and check the option to Hide All Microsoft Services. This option will display only the services started by non-Microsoft applications. Select the Disable All option. Click Apply, then click OK and reboot. WARNING: If you clear the Load System Services option on the General tab of the System Configuration Utility, or if you disable all Microsoft services on the Services tab, then all of the restore points for the System Restore utility are deleted.
      • If the system starts normally, restart the msconfig utility, choose the General tab, and select the box to next Process System.ini File, click OK and restart the system. If the problem does not reoccur, repeat this step for the Process Win.ini File, Load Startup Items and Load System Services options. If the problem reoccurs, the last item enabled contains the source of the problem.
      • If the problem reoccurs after selecting the Load System Services option, you can use the msconfig utility to load each service one at a time until you discover the source of the problem. Services can also be enabled or disabled via the Microsoft Management Console, or via the Computer Management Console.
Will not boot to safe mode imac g4
Starting up in Safe Mode Follow these steps to start up into Safe Mode.
  1. Be sure your Mac is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup sound, press and hold the Shift key. The Shift key should be pressed as soon as possible after startup, but not before the startup sound.
  4. Release the Shift key when you see the Apple logo appear on the screen.
After the Apple logo appears, it may take longer than usual to reach the login screen. This is because your computer is performing a directory check as part of Safe Mode.
To leave Safe Mode, restart your computer without pressing any keys during startup.
Sep 25, 2014 | Apple Computers & Internet
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
How to change boot for cd or hd in ibm lenovo
Start you computer and hit F1 every second until the Bios screen comes up. Then follow these instructions:
To view or permanently change the configured startup device sequence, do the following:
1. Select Startup.
2. Select Startup Sequence. See the information displayed on
the right side of the screen.
3. Select the devices for the Primary Startup Sequence, the
Automatic Startup Sequence, and the Error Startup Sequence.
4. Select Exit from the Setup Utility menu and then Save
Settings or Save and exit the Setup Utility.
Note : If you have changed these settings and want to return to the default settings, select Load Default Settings on the Exit menu.
May 17, 2012 | Lenovo Thinkcentre M55e 3.4 Ghz Pentium-d...
Windows 7 laptop won't boot to OS , only has a black screen with a blinking cursor
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language. Select your language, then select the option "Startup Repair". Click on it, and let it repair the startup. If it automatically starts correcting your startup then great! If not, then select your operating system from the list and click the Repair Startup option. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Mar 01, 2011 | Computers & Internet
LIKE HOW YOU START TO INSTALL AN OPERATING SYSTEM LIKE WINDOWS XP ,LINUX AND INSTALL SOFT WARE LIKE BORLAND C++,MICROSOFT,AND JAVA UP TO THE END.I WOULD ALSO LIKE TO ABOUT NETWORKING COMPUTERS PLEASE HELP...
In most cases, you startup your PC with a disc (CD or DVD) containing the OS. (OS=Operating System)
You may need to "enter the BIOS" to make sure that your PC starts from the disc. To do this, restart your computer, and press the F10 button while it starts, then select bootup sequence, select disc drive. If that doesn't work, you might need to press a different F-key, your PC should tell you, at the beginning of startup, "press F8 for advanced startup options" or something similar. Press that F-key instead.
If you want all your questions answered, I think you should enrol on a course at a college.
Feb 10, 2011 | Computers & Internet
My Friend just received a cleaned T21 from her workplace. When I try to boot it up I get the following: Initializing MBA. Pres Ctrl+Alt+B to Configure... Managed PC Boot Agent (MBA) V 4.12 UNDI Initialize...
try clicking on this link and choosing Master Boot Record Repair.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-56102
Also, have you tried
Step 1. Make the DVD drive the first startup device in the startup sequence using
the following procedures:
a. Shut down the operating system and turn off your computer.
b. Press and hold the F1 key, and then turn on the computer. When the logo
screen is displayed or if you hear repeating beeps, release the F1 key. The
Setup Utility program opens.
Note:
If the Setup Utility program does not open, shut down the
computer, wait approximately five seconds, turn on the computer, and
then immediately press and release the F1 key repeatedly until the Setup
c. Use the left and right arrow keys to select Startup from the main menu.
From the Startup menu, select Startup Sequence and then press Enter.
d. From the Startup Sequence [Primary] menu, do one of the following to
select the DVD device that you want to use as the first boot device.
Note: When selecting your DVD device as the first boot device, be aware
that internal DVD drives are listed as IDE CD. If you will be using a
supported external DVD drive as the first boot device, select USB
CDROM in the steps below for your choice of DVD device.
v If your choice of DVD device is already listed as the first boot device,
continue with step 2.
v If your choice of DVD device is listed in the startup sequence as any
device other than the first device, select it and press the Plus (+) key
repeatedly until it is displayed as the first boot device. Continue with
step 2.
v If your choice of DVD device is listed as an excluded device, select it
and press the X key one time to add it to the startup sequence. Then,
select your choice of DVD device from the startup sequence and press
the Plus (+) key repeatedly until it is displayed as the first boot device.
Continue with step 2.
e. Press F10 to save and exit the Setup Utility. When the save and exit
message displays, select Yes and then press Enter.
Jul 18, 2010 | Lenovo ThinkPad T21 2647 Notebook
Computer always starts in safe mode
Your OS might have been set on Diagnostic Startup. Verify this setting:
Start> Run> enter msconfig
On System Configuration Utility window, on General tab, make sure you have it on Normal Startup or anything other then Diagnostic Startup.
Oct 12, 2009 | Compaq Computers & Internet
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Setting boot sequence
press Del or F2 or Esc while booting ..
Feb 17, 2009 | Systemax ™ Mission Xeon™...
Dell Latitude C400 Notebook Logo
1,606 people viewed this question
Clive
Clive
Alun Cox
