Question about Dishwashers
My dishwasher won't fill with water. I've checked the float assembly inside the washer and it seems to work fine. I've been looking for the float switch and water inlet valve inside the bottom panel in order to 'test' them, but can't seem to easily find them.
    Scholar:
  • 61 Answers
If hot or both cold and hot fill try to switch the pipes
if not filling it may be a problem with program and or filter blocked
check also the pump
did you check the water is on as sometimes people forget to swith it on
if the motor has carbons as in the washing machine and if they are worn the water will not fill or better the motor is not going to turn and will not pump in water
as it is possible the pump may not work
this will make a sound like emptiness and with air in it
Posted on Sep 27, 2009
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
The dishwasher does not fill up with water, but when we manully add water, it seem to run through cycle. also, the buttons seem not work properly. If I want to rest, it will not activate when pressed.
Hi
Daniel
Aug 29, 2011 | Dishwashers
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water not coming in to washer
Hi
Daniel
Aug 27, 2011 | Bosch 23 in. SHU303 Built-in Dishwasher
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
When you turn on the dish washer it heats up but there is no water coming into the machine- quiet series 300
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 07, 2011 | Maytag Dishwashers
No water coming in the washer
Hi
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Dishwashers
Water will not fill the washer
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 24, 2011 | Frigidaire 24 in. GSB5712BC Gallery...
The washer is not getting any water. It is running dry.
Hi
Daniel
Oct 25, 2010 | Kenmore Dishwashers
Dishwashers Logo
188 people viewed this question
Top Dishwashers Experts
