Question about Diamondback Cycling
Broke both grip shifters...where to find and replace and how. Diamondback men''s bike
    Problem Solver:
  • 5 Answers
Http://www.nashbar.com/bikes/SubCategory_10053_10052_200468_-1_200276_200313
this is where you can get the shifters, there should be instructions with them or go to the sram website
Posted on Sep 27, 2009
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
The chain feels and sounds like it's jumping gears or slipping on the rear sprockets. It does it in all gears. It is a diamondback wildwood large 20"
The rear derailleur needs adjusting, once to establish limits (so it can't go past high gear or low gear). Everything else is up to you fine-adjusting the shifter to make the bike run quietly. If you're careless about your gear changes, you'll get MOSTLY into one gear but not quite perfectly, so the bike is always trying to start shifting into another gear - that's the sound you hear, the sensation you feel. Fine-tune your shifter positions each time you shift - you'll find a "sweet spot" where the bike runs almost perfectly silently.
No, they can't readily do that at the factory, not with chain drives. There are just too many things that can affect gear changes, and things are in a slightly different position every time you remove & replace the rear wheel, or even loosen & retighten it. Unless you're ready to spend vast dollars on a foolproof shifter system, shifting cleanly is going to be your job and your job alone. It's one measure of your bike riding skill... and the better you get at that skill, the better you feel about it.
...and your bike will like you for it.
Jul 30, 2014 | Diamondback Mens Wildwood Classic Comfort...
Can handlebars on diamondback insight 2 be raised?
typically not, they use an Aheadset style headset. If you need them higher then your dealer or local bike shop can help you pick out a stem that has more "rise" to it so you can sit more upright.
Jan 19, 2013 | Diamondback Insight RS 700c Men's Hybrid...
I have the Shimano Rapidfire Plus shifter on my Topanga bicycle and it started to not shift it just has free play! I try to shift it and it just moves free and once and awhile it will shift. Will I have...
It may be fixable.Try to clean it and then tighten the cable that is on the rear of the shifter assembly.Then make sure the controller is tight and clean.If it still wont work check to make sure the mounting bracket is not bent.The mounting bracket may also have an adjuster on it.
May 11, 2011 | Diamondback Topanga 26 Men's...
I have a diamondback serene women's bike, can't shift into 3rd gear. grip turns extremely hard and then if I get the shifter to 3rd, the gears on the bike just click. have to ride it really hard and...
Many possibilities, including derailleur outer limit not correctly adjusted, derailleur not mounted correctly, tight bend or friction in cable. Talk to the store manager/owner about correcting your complaints or find another shop or a bike co-op. If the bike is a major brand from a bike shop (Trek, Giant, Cannondale, etc.) try going to their website, look for Customer Service/Support and enter a complaint.
May 23, 2017 | Diamondback Serene Citi Classic Women's...
How do I operate the gear shifters on a diamondback sorrento?
Here's a great article on that subject. The article covers virtually any multi-speed bike, including yours. One thing the article leaves out is that in order to shift, the chain must be moving, which means that you must be pedaling. But it works best if you are pedaling very lightly.
http://bicycleuniverse.info/eqp/gears.html
Jun 30, 2010 | Diamondback Sorrento 26" Mountain Bike
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
Front shifter problems
take the grips off and wrap some friction tape around the handlebars about half to three quarters the length of the grip from the end of the bars. then put the grips back on. shouldn't need more than 3 layers of tape
Jul 28, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Grip shifter slipping
It sounds like the catch mechanism inside the shifter may be broken. I found a video that does a 'how-to' to give you an idea of the internals of these types of shifters (may not be exacly like yours). If your shifter does not click and hold each of the 3 speeds, this is likely the problem. Sometimes this can be repaired or you may have to replace the shifter. its best to call your local bike shop and see if they carry parts for your shifter. Make sure you have the make and model noted - or just bring the bike down.
Video
Apr 21, 2009 | RTO Mens Single Speed 26" Deluxe Beach...
Cycling Logo
161 people viewed this question
Top Diamondback Cycling Experts
Tony
Lloyd Carter
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
