Question about Sharp LC-26D6U 26 in. LCD Television
Turn it on power comes on cycle thru cable seek and then no picture. 3 or 4 times then the picture comes on....help
    Problem Solver:
  • 9 Answers
In all the time that you had the tv have you ever had the 2 firmware updates applied that all the D6U tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. I think this may fix your issue. You must take it to a repair center to apply these updates because they are not available for you to download and apply yourself. Call Sharp at 1-800-237-4277.
Posted on Oct 07, 2009
Sony KDL-40XBR2 - powers on, backlight is on, no pic, turn it off and back on, same for 10 to 15 seconds, then TV does power off/back on by itself...most of the time picture then shows up.
Depending on your enegy, on home, if is variable or steady 110V
you can check these on your TV, but safety first, or seek a qualify tech:
1) bad capacitor for power module **
2) bad inverter board or capacitors burn.
good luck!
Jan 16, 2017 | Sony Computers & Internet
Insignia TV has jumpy picture is it the settings or connection
I would first start by checking the connections to ensure they are secure. Also check and see if by plugging it into a different source outlet, if that would resolve the issue. You can try replacing the cables to see if that helps too. If not, then it would most likely be a settings issue. Try to power cycle it: turn it off, unplug it and leave it unplugged for a few minutes. Turn it back on, plug it in and restore settings to factory defaults.
Still experiencing issues: You would need to seek service repairs.
Jan 26, 2014 | Televison & Video
My lg tv picture wont come on
After turning the equipment on try pressing guide or menu to see if that makes picture come on. if not try disconnecting and reconnecting the cable going from cable box to T. V.
Nov 10, 2013 | Televison & Video
How do i get the menu back on the screen dvd player
Unplug the device from AC mains wall socket, and plug it back after 5 minutes or so. This must make a hard reset to your device. If it do not help you, enter into its menu and make it a factory reset. If this too do not help you, seek tech support.
Jun 06, 2012 | Televison & Video
I have a Sony KDL-32M3000 LCD TV.. When I turn the tv on you can see the screen lite up with no kind of picture, Almost like a lite comes on then goes out the the lite comes on again with no picture but I...
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!!@#
Mar 25, 2011 | Sony KDL-32M3000 32 in. LCD Television
Machine takes a long time for first cup to come out then sometimes only half as much water as used to comes out
mcdevito75 here, sounds like your coffee maker needs cleaning, after 20--30 cups of coffee made it does. Fill the decanter with white vinegar, clean or place new filter in the machine and cycle the white vinegar thru 3 times, on the 3rd time time thru stop the machine for 30 minutes, then resume that cycle. Now clean or replace the filter again and cycle thru regular water 3--4 times the get rid of all the vinegar, machine shouls be fine now.
Jul 07, 2010 | Keurig Special Edition B60 Coffee Maker
No picture thru hdmi but picture thru RCA plugs
I had this exact same problem, or rather my friend did after I borrowed his PS3. You see when I borrowed it, the console configured the HD output to work with my TV, If this happened to you, there is a fix, With the HD cable connected, turn off the power to your PS3 and then turn it back on again. But when you turn it on, hold down the power button until you see something on the screen. When you hold down the power button of the PS3 when you are turning it on, it completely resets the video settings to the most basic settings (480p I think) so that it'll work on any TV or monitor. Once you can then get something on the screen, you can configure the video settings to match the TV you are hooking up to.
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sharp LC-26D6U 26 in. LCD Television Logo
110 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
