Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
Can i use it in bridge mode? - 2wire HomePortal® 1800HW Router (1000400212000LNR)
  • 4 Answers
Yes.. just place the ethernet cable in place... Remember it is much easier to connect wired than wireless
Posted on May 02, 2010
Access to bridge mode
What do you want to know? How to put it into bridge mode or how to get it out of bridge mode?
It depends on what driver you install for this device. The WAN driver gives you PPPoE/A and the LAN driver gives you bridged mode, Dlink appear to have a tool for removing drivers which I see as a very bad sign.
This is a pretty old device - the drivers I'm seeing go back to Windows 98 and Mac OS9...
Apr 05, 2012 | D-Link DSL 200 (DSL-200) Modem
Bridge router
1. Use both the Modem and the router as NAT routers. Do this by making your router a DMZ node on your modem, that way ALL traffic will pass to the router, then set up port forwarding etc on the router.
2. Run the router/modem in bridge mode (recommended). You need to set the modem to run in bridge mode, check the user manual for refrences to bridging. Then set the router to connect to PPPoE using a username and password.
Jun 07, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
Hi there, i just had telstra install a Cisco 857w router. i am trying to setup the wrieless and am having no luck, i am not very computer literate so i may need to explained in very simple...
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
interface Dot11Radio0
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
authentication key-management wpa
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Jun 09, 2009 | Computers & Internet
Bridge II only displays Album title
I had the same problem with my HK AVR 355 and The Bridge II.
Yours has entered manual mode by itself?! You think the bridge it did by itself but You did it.
I tell you how! I had the same problem but it's not problem but a lack of user's manual. In the automatic mode the searching through albums and artist on the on screen display is very slow. You are pushing and pushing and pushing the "menu" button. That was the problem!
Connect your bridge and ipod and turn on the AVR. Switch to The Bridge as input. It will say that you are in manual mode. Push the menu button on the AVR's remote for a few seconds. And it will turn back to automatic mode!!! That's all!
The real problem is neither of two manuals (The Bridge and AVR) tell any words about the function of holding down for seconds the menu button. Its function is to switch between manual and automatic mode!
Feb 21, 2009 | Harman Multimedia Harman Kardon...
How to put dsl-320T in full bridge mode?
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
May 18, 2008 | D-Link Computers & Internet
Bridged
setup of bridge mono mode:-1-turn your amplifier off.2-connect input wiring to channel(1) input--3-connect speaker across positive outputs terminals-do not use negative terminal when amplifier is operating in bridge mono mode.4-turn down (fully counter clockwise)of channel (2).
Mar 13, 2008 | Crown CE1000 2-Channel Amplifier
Sound
Hi monmax,
I hope you are aware that in bridged mode your amp will become monaural (single channel, double power). If you still wish to bridge it:
Switch of power.
Set mode switch behind amp to "bridge" position.
Connect speaker positive to CH1+ve terminal of amp output and connect speaker negative to CH2 +ve terminal.
Be aware that now, in bridged mode your amps output power delivery is 1100 watts for a 4 ohm speaker and 900 watts for an 8 ohm speaker. Make sure your speaker can handle that.
Peace
Jango.
Mar 03, 2008 | Crown CE1000 2-Channel Amplifier
Yamaha P4500 Power Amplifier 2-Channel Bridge mode
im from Yamaha service before and i know this model can handle as low as 2ohms per channel. I have to check on my manuals though if bridged. i dont see any reason why it cant. and it has a bridge option input stage... let me get back to you again in the days to come.
or email me redrivera0314@tyahoo.com
i have a service manual to check on this. got to dig on my closets..
Mar 14, 2007 | Yamaha P4500 Power Amplifier 2-Channel
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
116 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
