Question about Garmin Nuvi 760 Handheld GPS Receiver
My garmin begins to load and them goes blank - Garmin Nuvi 760 Handheld GPS Receiver
    President:
  • 1,111 Answers
Plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update
(actually i would do this either way)
bill
Posted on Sep 27, 2009
Testimonial: "This did the trick, great job!"
Garmin nuvi 1450 can't start. it goes blank while loading maps
If you can connect the unit to the PC update it using Garmins WebUpdater Software. If you are unable to do this you will have to send it in for warranty or repair. The 1xxx series did have an issue with one of the firmwares releases where the unit would lock up and cycle.
Hope this helps!
Mar 18, 2011 | Garmin nuvi 1450 GPS Receiver
Turned on the Garmin nuvi 1200. the Garmin logo comes up, loading maps comes up then it goes blank and begins the cycle again. I have held the power button down nothing. I have touched the bottom right of...
Hi! Please try inserting a paperclip on the reset button. Press hold for atleast 15secs. and this can resolve the problem. Hope this helps and thank you for using FixYa!
Oct 16, 2010 | Garmin nuvi 1200 Car GPS Receiver
Screen went blank and when we restarted it the screen comes up as if you're restarting from the beginning when you touch the onscreen icons the screen is locked. How do I unlock it?
its a common occurance on this unit. send it back. it blows fuses, screen maps goes blank with only square dots and no streets. the refurbished units also have these problems.
Sep 20, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin C350 does not stay on. I get the GARMIN screen and then it says that it is loading and then the scrren goes blank.
Probably needs a firmware restore. Google for a guide, if the restore fails, you need a new logic board. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
Jun 27, 2010 | Garmin StreetPilot c530 GPS Receiver
Garmin just shows its loading maps and then screen goes blank and it repeats this even when I hold down the button for 10 seconds to reboot Why is it not turning on?
A Garmin Nuvi 1300 freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
SHUTDOWN
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 12, 2008 | Garmin Nuvi 660 GPS Receiver
Won't stay on
Have you installed anything lately? Do you have any sd card installed? Usually this is the cause for it to crash. There is a reset on the bottom of the nuvi, when it locks up blank, press the reset button and see what happens...
Jul 07, 2008 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
