Question about Samsung HLM507W 50" Rear Projection HDTV
Samsung hlm507wx with ''clicking speakers''?
I have a hlm507wx 50in Samsung dlp TV. I recently replaced the lamp due to the previous one dying. for the past couple of years now the speakers have been ''clicking'' I'm thinking its the ballast going bad but I'm not sure. the sound only clicks through the TV speakers but it doesn't stop. I still have sound through my external sound system but the TV speakers continuously click. and more recently the fans started making a lot of noise. any advise as to how i could further diagnose the problem and how much the repair item(s) would cost. I'm a certified technician and would be able to do the work myself but its the cost of the parts I'm concerned about. Thanks for the help, ~Matthew~
Matthewdwigh,
I have the very same tv with the very same problem of clicking noise coming through thr speakers. Were you able to resolve your problem and if so can you tell us what part solved it?
Posted on May 11, 2010
  • Samsung Master
  • 5,138 Answers
Color Wheel could be a problem also,Ballast Board is what turns Lamp on I would start with ballast Board and if you hear a whinning noise when set is coming on color wheel needs to be replaced then!
Encompass 1-800-638-3328 and you can find some gool deal on E-Bay i got my ballst board for 62.00 and my Lamp for 85.00 CK it out! Just typ in your model number Parts/ or Ballast boards
Posted on Sep 27, 2009
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
No picture
Check the lamp contacts, eventually remove lamp and fit back in, chack that you did not burnt new lamp when mounting it in, you need a multimeter to test lamp.
Aug 10, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung HLP-4667W DLP TV has no picture when I turn it on.
The color wheel can be ruled out by looking at it---it faces the lamp and can be seen---look to see if any segments of the wheel are missing or if the wheel is totally shattered.
Other than the wheel I am concerned by "blue splotches etc" as it might be a DMD gone bad. Look at the attached photo and the color wheel first.
May 03, 2012 | Samsung Televison & Video
I am having the same issue with white spots on my screen. My TV is a 50in Samsung HD DLP Rear Projection that was purchased about two years ago. What is the most common fix to this problem? Thanks for...
The DLP chip is failing and must be replaced. You can call 1-800-samsung to find out if this is covered under any special warranty and to find the nearest service center.
Jun 21, 2010 | Samsung SP50L6HX 50" DLP HDTV
HLS5087W DLP Samsung Fan problem
Replace it if fan to Lamp stops running this will fix problem Call Mats 1-800-628-1118
Sep 16, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Loud pop and picture went out.I have sound but no picture.
I had this happen a few months ago. More than likely the color wheel died. I opened up the back of my Samsung DLP expecting to find a blown lamp, but came to find out that only the color wheel was in need of replacement.
Sep 26, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung hlm507wx/xaa
Hi..your temp. sensor tells you when your lamp is too hot and could possible melt your engine. That is why your TV shuts down. It could be your lamp fan is not working or not working good enough to cool your lamp. You may need to replace it and very easy fix.
Mar 25, 2008 | Samsung HCJ552W 55" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
259 people viewed this question
Jerry Greenberg
Jerry Greenberg
