Question about Sony KV-27S42 27" TV
Turns off automatically after turning on.
It turns off automatically after turning on. I have to shake/tilt/move it to a different spot and then it stays turned on. once i put it back on to the entertainment center it turns off automatically after i turn it on.
it seems like something is loose.
i had this problem once (3 years ago) and i took to a repair shop and they told they couldnt fix it and they told me that that they would thrash it for free. I was reluctant and brought the tv back and it started working.
now i have the same problem. My friend kids me that i need to take the tv on a ride and bring back home and it should work.
please help me.
thanks.
  • 275 Answers
SOURCE: TV won't turn on
Unless you know Solid State Electronics, there is nothing you can do. At best, You could unplug the TV, remove the back cover, slide out the Circuit board, and check the fuses. They will be at the front of the Circuit board, left hand side. But in all likelihood, it is not just the fuses, the Power Regulator STR would also be short circuited (happens often in SONY TVs) and so it is best that a professional technician have a look.
Posted on Sep 27, 2006
  • 236 Answers
SOURCE: fd trinitron kv-27fs320
I think you may have a cold solder joint or burned loose connection somewhere in your power supply. Also maybe a crack in the circuit board. apparently when you moved the tv you "fixed" the problem temporarily. Stargazer
Posted on Jan 28, 2007
welcomejee
  • 10594 Answers
Hello Bob61E,
life safty should be 1st priorty before opening of TV set ;)
if you are skilled or qualifeid, then go-ahead and
if its Sony TV, you will see stand-by light blinking while tv try to power up. let me know how many time this light blinks.
Posted on May 28, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KV36HS500 won't turn on
3 times blinks shows problem of failure of IC6505 in DZ board. If you know basic electronics, open the back cover of tv and go ahead.
Posted on Jul 20, 2008
  • 476 Answers
SOURCE: SONY KV-36HS500 will not turn
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Posted on Aug 12, 2009
Testimonial: "This TV expert was on the money and clear with instructions. While I couldn't fix my TV, the advice was accurate and I will hire a pro to fix my set."
Why does the touchscreen keep tilting g upward each time I put my car in re else?
read the instructions again It sounds like that might be an automatic feature to get it out of your vision while backing .
Jul 20, 2015 | Crown Ouku 7" Double 2 Din In Dash Car Cd...
Took apart camera to clean put back together didn't turn on opened up moved a little it turned on but when I close it all back up it does not turn on.
Put the back on with one screw, try it. IF it works put in another screw and try it, do this until you find the problem. If you have screws that are different length, you may have one in the wrong spot.
Aug 23, 2014 | Samsung L200 Digital Camera
My ipod won't tilt or shake anymore? How do I fix
Thus was just happening to me and I turned my iPod off for a day or two and then turned it backon
Jul 08, 2010 | Apple iPod touch
I have an ACER ASPIRE 3000 it automatically turns off
you pc is in safemode , need to put it back in normal mode , when you start the pc , look at the back screen and read normal mode and move the cursor in to normal mode and click enter you might have 20 seconds to do it
Aug 04, 2009 | Acer Aspire 3000 Notebook
Xbox 360 Wired Controller Busted
Yeah I foudn the problem. I just found out one of the wires was broken inside, right above where the controler meets the wire. It was a grayish wire, probably the one that turns it on. No wonder it would only turn on if the wire was in a certain position, it was connecting the wires! Problem solved.
Aug 17, 2008 | Microsoft Xbox 360 Controller
Nikon az1 auto level
There are 2 allen screws on the fish eye bubble that can be adjusted to correct that problem.
First level the instrument;
Then turn 180 degrees
Adjust the vial until the bubble is half way from where it is back towards the inner circle.
Relevel the level using the foot screws
Then turn 180 degrees again (back to where you started)
It should be mostly fixed, however if it is not just repeat the steps above; it gets exponentially better everytime until you can no longer detect the error.
Aug 02, 2008 | Nikon Optics
Brake Lights
My 2002 did the same thing today and I'm looking for a solution. It has drained my battery twice today. Please advise if you find anything out. susanrossman@yahoo.com
Jul 10, 2008 | 2002 GMC Envoy
Hi Guys, here's my problem - How to lower the whisk on a KitchenAid KSM90? My whisk is not close enough to the bowl. Thanks so much, Helen
ok firstly if you have a stand mixer with the lift bowl you have to put a dime on the side of the bowl at the base and see how much clearence is needed to be taken away. if the dime gets moved the mixer is ok. if not take off the flat beater, take out the bowl, and look at the back of the stand. just below the motor about 2 inches you will see a screw. turn it to the left a quarter of a turn. dont over adjust do it slowly. if you have the one that you tilt the head back on do the same thing with the screw up to you get to the adjusting part. the screw will be in a different spot on those mixers. it is located in the neck of the mixer. it is right in the area that tilts back. the dime shouldnt fly around the bowl it should just gently get tapped. and never use the wisk when adjusting always use the flat attachment. and always adjust slowly never over adjust.
Apr 11, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Sony KV-27S42 27" TV Logo
136 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
