Question about Car Audio & Video
Is there a radio that has 4 preamp rca's or more?
    Top Expert:
  • Car Audio & ... Master
  • 76,630 Answers
No there are only two preamp plugs, you can split them for more channels
Posted on Sep 27, 2009
Kenwood kax-38 amp. distorted sound from turnatable if connected to the phono rca plugs, but ok if connected to the CD rca plugs.
The phono sockets for this are at different line levels for that reason. Phone is for the turntable depending on the type. If it is a later model stereo and an older model cheaper turntable, it uses an older type of needle cartridge called ceramic. The signal output of it is higher than the later magnetic cartridges and may need a preamp (radio shack) to match the line level signal, allowing it to clear the distortion. If this scenario were reversed, using an older cheaper stereo with a later, better quality turntable, the opposite would happen. (signal to low) This preamp would amplify the input. I think you need what is called a matcher to lower the input signal instead of the preamp. I've seen these at radioshack. BTW, the CD input doesn't distort as much because a cd player puts out a high signal and the amp is matched to accept it.
Dec 03, 2013 | SR-10 Adpater Cable - Kenwood Twin-Pin...
How to hook up car radio to an amp when radio does not have RCA Jacks
They make a type of Amplifier that uses high level input from the speaker outputs. Contact a company called Crutchfield.com for details and prices. You ca also have a radio shop install preamp output RCA jacks to the factory radio, do an Internet search for shops that do this type of retrofitting.
Apr 29, 2012 | Cars & Trucks
I would like to add a turntable to my Bose Cinemate II but when i plug the RCA directly into the Bose module the volume has to be to the max and is still very quiet
You need a preamp to solve that problem, the older amps and receivers had built in phono inputs with a preamp stage. Radio Shack use to make a preamp that ran on a 9volt battery for turntables that ran into the very problem you are talking about. But I do not know if they are still available, go to www.ebay.com Type: turntable or turntable preamp
Apr 07, 2012 | Bose Cinemate Digital Home Theater System...
How i can install external page port of a pabx Norstar with output of 600ohms to the input Radio shack 250 Watts PA.
Connect Nortel PABX external page port output to the amp input.
Either by phone plug or RCA connector, any of the two will work.
Apr 19, 2011 | Radio Shack 250 Watt PA Amplifier...
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
Is there a way to hook up a bass system to a factory radio that dont have rca jacks
local radio shops can tap into the preamps and install the RCA jacks, seen this done many times, contact a car audio sales and installation center for details
Jul 01, 2010 | 2002 Oldsmobile Alero
Wiring an interconnect
Radio Shack sells an XLR to 1/4" jack converter. The you'll need a female double RCA to 1/4" plug in series with it
Apr 19, 2010 | Behringer EUROPOWER EP2500 Amplifier
I have a 2007 ultra with harmon kardon stereo i have a sirrius sat wired in and plugged into the deck poor volume. does this deck have rca jacks to plug in amp
No RCA jacks stock, But Iron Cross Audio had a custom program to install RCA preamp outputs into that unit. (www.ironcrossaudio.com)
Feb 17, 2010 | Harley Davidson 426290 AM/FM Radio
Bang and Olufsen 1980s Sound System. Broken input jacks for turntable. Broken Tape deck. Local repairers say they can't repair it because no spares
You will have to pay for the labor, if it's just truly broken RCA phono jacks, you can have them replaced by any ham radio guy or electronics guy with a soldering iron. It won't look perfect, but it will work just fine if it's only the jacks and not the switching circuitry. Radio Shack even carries (carried) single RCA chassis mount jacks to fix this.
Nov 10, 2009 | Audio Players & Recorders
What do i need to install a subwoofer
Here's what you need:
1) An enclosure for the 8" subwoofer.
2) 8" subwoofer.
3) Amplifier to power the sub.
4) Amp wiring kit.
Your Sony has two sets of preamp outputs so make sure that your wiring kit includes a set of RCA's.
Mar 24, 2009 | Sony Car Audio & Video
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
