Question about HP Photosmart E317 Digital Camera
My E317 won't turn on at all. It has new batteries and still won't do anything. I've had it for a few years, and it's had this problem for over a year and a half. I'm about to buy another camera, but I wanted to make sure this one won't work before I spend money on a new one.
3 Suggested Answers
  • 54 Answers
SOURCE: camera won't turn on
I am assuming that the power does not go on or it immediately turns off as it is turned on.
Try the docking station or the 3.3 AC adapter to the camera. Plug that in to live power. If you hear the lens motor (by default the lens is retracted to closed position when plugged to AC power), then the camera is operational. If not, there is power failure with the camera.
If the lens motor work, then try to turn the camera while plugged to AC power. If it turns on, then there is something wrong with the battery or with the chamber. If the camera does not turn on, then check the button board for a bad power switch.
Check the LCD closely under a bright light when you do this test. You may see a faint a flash of display that disappears. I have not figured out what causes this. This would mean that camera power supply is working but nothing is telling for the camera to stay on.
Posted on Dec 10, 2008
fblock
  • 289 Answers
SOURCE: camera will not start
Be sure the batteries that were in the camrea did not leak. You can use a pencil eraser to lightly rub on the battery contacts to make sure they are clean and reinstall the new batteries. This may fix the issue also since the contacts "may" have oxidized.
Posted on Apr 30, 2009
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
My 2001 dodge grand caravan sport won't start
DOES THE VEHICLE MAKE ANY NOISE AT ALL WHEN THE KEY IS TURNED?, IF YOU GET A "CLICK" BUT NOTHING ELSE THEN THE STARTER IS JAMMED, GET A HAMMER & GIVE THE STARTER A FEW SOLID FIRM BUT NOT OVER ZEALOUS WHACKS, MAKE SURE THE BATTERY IS FULLY CHARGED & TURN THE KEY, IF ITS ANYTHING LIKE ALL THE CARS I'VE HAD OVER THE YEARS IT WILL MAGICALLY SPRING TO LIFE - IF IN DOUBT - GIVE IT A CLOUT!!
Sep 02, 2012 | 2001 Dodge Grand Caravan
My mobile battery not charging
POWER SUPPLY & BATTERY PROBLEM
If thecell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.ORThe charge adapter is faulty. Test the voltage on the adapter plug with a multi-meter, the voltage should be slightly higher than the voltage on the label on the charge adapter.
Apr 27, 2012 | Samsung SGH-e317
Have f11 fault tried to reset and machine starts up, turns a few times, then gives a strange noise then f11 appears and pump starts draining, had f11 few years back and was fuse but remember at this time...
sounds like you've either got a stiff motor or gunk in the drum making it difficult for the motor to turn. When the fuse blows the drum won't turn at all but as yours is trying to turn then throwing the fault up it sounds like something is causing too much resistance
Aug 26, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Wont turn on
replace cell battery with new one
Jan 25, 2007 | Samsung SGH-e317
HP Photosmart E317 Digital Camera Logo
76 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
