Question about RCA Televison & Video
The picture on my r52wh74 rca tv looks like it is in 3 d what may be the problem
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sinkthe picture on my r52wh74 rca tv looks like it is - 2.gif. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
asnowman
Posted on Sep 27, 2009
    Problem Solver:
  • 10 Answers
Mine did that. I contacted tvrepairworld.com and they sent me a cd and parts to fix it for $25. Can't beat that. I did what they said and it worked. Takes some soldering technique but wasn't hard to do.
Posted on Nov 01, 2009
I have a rca Model R52WH74 which the picture resolution is given out. Please tell me what can I do to fix this issue? It look like the picture is in 3D
Jun 25, 2010 | Televison & Video
Picture is bent. color is a bit fuzzy and 3 lines
Ur convergence it dead,know how to solder?Buy a convergence kit use what in that kit.Tries websites Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA HD52W59 HDTV Projection Television
Rca r52wh74 looks like i am watching 3-d. red, blue ghost lines and picture looks stretched out
The ITC 222 convergence option missing repair kit available at www.tvrepairworld.com usually will fix that issue. The kit contains the parts and CD with instructions
Sep 24, 2009 | RCA R52WH73 Projection Television
RCA R52wh74 with 3-d picture
sounds like you have a convergence problem my friend, if you are handy you can Google a kit with all the parts for your set and save hundreds of bucks!!!!
Larry Dillon
Aug 11, 2009 | RCA R52WH73 Projection Television
Problem with my rca projection television
my RCA R52WH74 HDTV IS STARTING TO LOOK BLURRY. ALSOMY SCREEN LOOKS LIKE IT STRETCHING MY TV PROGRAMS....... CAN U GIVE ME A SOLUTION
Mar 16, 2009 | RCA HD52W59 HDTV Projection Television
Locating the ''flyback transformer '' on a rca mod #R52WH74
It is usually large and black. Its the one with the rather thick red wire coming out of it. The other end of that wire either connects directly to the picture tube or into a distribution block which distributes the high voltage to the 3 picture tubes (guns) in projection TV's. Be aware that this transformer produces high voltage and can store voltage even when the set is unplugged. I hope this helps.
Mar 10, 2009 | RCA Televison & Video
RCA R52WH74 Picture is sagging, looks 3d, and double picture
Go to menu then setup look for convergence if you do not see convergence then you have A open FUSE It will be on right side of FBT flyback transfomer there is 3 of them in a roll they are small brown rectrangler looking caps but ARE FUSES it will be the one in the middle. Replace it and you have a FIXYA.
Feb 19, 2009 | RCA R52WH73 Projection Television
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
171 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
