Question about Roper FES330 Electric Kitchen Range
Where do I find the fuse on a Roper oven? - Roper FES330 Electric Kitchen Range
How to locate fuse in Roper microwave model No. MHE14XKB
After removing the cover (most microwaves use security screws) the fuse will be on the circuit board near where the power cord connects. It will look like a glass fuse but is made of ceramic. Most have pigtail leads and are soldered directly to the board. Do not ever operate a microwave with the cover off.
Aug 18, 2016 | Roper Microwave Ovens
1965-70 roper wall oven gas any information on how do I turn on the oven is appreciated, the pilot is lite
I already sent you some advice...read it! It tells you to go to the Roper Wall Oven website. Roper makes alot of products and sends them out to the stores with an owner's manual in each box!
Dec 27, 2012 | Ovens
All works except turn table and will not heat
Check the Main fuse inside the oven.And check the cause why it trip.
if it fused then check the transformer physically for sign of burnt.
I all above things okay.Then you need DMM to check the resistance of magnetron(oven has 5000 v in it even unpluging from main)(please dischage capacitor if you want to live more).
Thanks
Please rate my work
Sep 19, 2011 | Roper MHE14XKB Microwave Oven
Can't get roper microwave oven to heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhhdg
Apr 22, 2010 | Roper MHE14XKB Microwave Oven
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
Won't turn on outlet tests good but no power
Probably a blown fuse inside. You will have to remove the cover to access it ... probably a type ABC and 20 Amp
Jan 07, 2010 | Roper MHE11REB Microwave Oven
Roper Self cleaning Oven
how dirty is the oven? if it is not bad then 2 hours if it is then 3 hours.
make sure you don't have any pet birds in the house cause it could be toxic to them.
Oct 31, 2008 | Roper FEP320 Electric Kitchen Range
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Rita
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Mar 22, 2008 | Microwave Ovens
Microwave does not heat
check the control panel and related circuit,and check the door lock switches ,..
Sep 27, 2007 | Roper MHE14XKB Microwave Oven
Roper FES330 Electric Kitchen Range Logo
658 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
