Question about Apple iPod nano
How to setup my ipod nano
I downloaded the software for it which is itunes and then connected my ipod to the comp. but it does not seem 2 work if someone could help me greatly appreciate
  • Anonymous Dec 23, 2007
    I down loaded itune software. I click on program and box comes up that it can't find or create "iTunes" folder that by default in should be in folder "My Music". I can put data on ipod drive but it doesn't show up or play anything.
  • Anonymous Jan 01, 2008
    tryed downloading itunes but it still wont work
Tell me the steps to install and play my ipod nano
Posted on Jan 05, 2008
    Problem Solver:
  • 15 Answers
It sounds like you might need to change some of the itunes settings. you open itunes and plug your pod in and see if it shows up on the left side of the window in with the playlists. if it doesn't then there is an interface problem which could be something as simple as the cable. if it does show up, then you click on that icon and you can change your pod settings.
Posted on Dec 20, 2007
My computer does'nt recognize my ipod nano a1199emc
You need to have iTunes. You can download the latest version at www.itunes.com. After the setup, plug in the nano.
Jan 01, 2012 | Audio Players & Recorders
When I try to download music from pc to my ipod, pc says connect
Hmmmm check wit the data cable once.. try using different USB ports els different data cables itself..
- if cable workin fine den try doin a hard reset.. i.e with d iPod plugged in 2 d comp try resetting iPod..
-Els check if ya iPodz getting recognized in iTunes.. if itz gettin not gettin recognized reinstall the itunes software.. or follow dese steps-
1>www.apple.com
2>Click on the tab SUPPORT
3>Select iPod+iTunes
4>Select iPod nano 4 r 5th gen
5>U'l find many divisions as get started troubleshooting n al.. under troubleshooting d 3rd link i.e iPOD DOESNT APPEAR IN ITUNES n follow d steps
-if itz gettin recognized in iTunes n not gettin recognized in comp den follow d same steps til troubleshooting.. under dis go to d 4th link i.e iPod is not recognized properly by computer when USB drivers are not installed properly r out f date..
Try wit al dese steps.. hope sumthin works out 4 u..
If none f dese work den derz another step to it.. may b disk mode step which am not sure f.. try finding out regardin diskmode n may b dat'l help ya..
May 26, 2010 | Apple iPod nano
I have just bought a second hand ipod nano generation 3 and it worked fine until I clicked onto the reset settings. It now seems to have locked and i have no idea what to do ? PLEASE HELP
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
f the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
All this can be found here: Click Here
Mar 19, 2009 | Apple iPod nano 3rd Generation
Computer wont recognize ipod
ok if u have windows u need to do a search and type in anything that has to do with ur current iTunes and delete everything but the music folders and after u need to reinstall itunes and then plug in ur ipod after iTunes is open and try restoring the ipod.
Feb 28, 2009 | Apple iPod nano
My ipod nano 3rd generation lost its memory
How to restore iPod (ARTICLE NUMBER HT1339)
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
Dec 19, 2008 | Apple iPod nano 3rd Generation
Ipod not resetting,not recognised by comp
Please load itunes ......www.itunes.com
Oct 01, 2008 | Apple iPod nano
Ipod nano locked
How to restore iPod
Jul 25, 2008 | Cameras
PASWORD TO IPOD NANO
Ah
You need to perform restore to remove the password
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
May 09, 2008 | Apple iPod nano
Apple ipod nano 4GB silver model no A1236
i dont have the instructions for this ipod where can i go to get the instructions to learn how to work it and download music from my computer to the ipod
Feb 09, 2008 | Apple iPod nano
Apple iPod nano Logo
76 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
