Question about Maxdata JOHNSON & JOHNSON / Band-aid brand antibiotic adhesive bandages, assorted sizes, 20/box / JOJ5570 / ... Server
How do i remove residue from sticky band aid with no pain? the residue has been building up do to where i had a dr make a cut in my arm and now the skin is irritated and very very sticky.
    Problem Solver:
  • 5 Answers
Rubbing Alcohol on a cottonball.
Posted on Sep 27, 2009
Radio case perished and sticky
Depends on what the product is. Alcohol works on a lot of products . So does plain water if it cuts the sticky substance.
Aug 07, 2016 | Maycom AR-108 Air Band Scanner
I have been ask to take Naproxen as pain relief, for an arm injury but it's having the adverse effect, I am experiencing severe pain in the lower arm. Why?
I would call the doctor right now or head to the emergency room with the arm pain you are experiencing. Better safe than sorry.
Apr 12, 2016 | The Health & Beauty
How do I stop baumatic dishwasher leaving a sticky residue on glasses and other articles on the top shelf?
Make your dishwasher more effective with these quick tips: 1. Check the sprayer arm. When I opened the dishwasher door during a wash cycle, I learned that some of my utensils are too tall, and they blocked the sprayer arm from rotating. Problem solved! Also look at the holes on the sprayer arm to make sure they are not clogged. Use a toothpick if you need to dislodge anything.
2. Check the drain. Look inside the bottom of the dishwasher and remove any food or objects from the filter. Run the garbage disposal to clear it out before turning on the dishwasher since they share the same drain.
3. Don't overuse detergent. It's a mistake to assume you should always fill up the detergent cup. Check the manual and your detergent. On mine, filling it to the first line (about a third) is enough. Too much detergent can leave residue and etch your glasses.
4. Check your water temperature. If it takes a long time for the hot water to reach your kitchen sink, that means the dishwasher isn't getting enough hot water at the beginning either, and that makes it harder to wash away the food particles and grease. If you need to, turn on the dishwasher after you've used hot water at the kitchen sink.
5. Clean the inside of your dishwasher. Grease, detergent residue, and calcium deposits build up inside your dishwasher. You can use vinegar to wash them away. On a regular basis (every few months or so), run a wash cycle while your dishwasher is empty. Don't use detergent, but turn on the dishwasher and let it run for a few minutes until water starts to fill up the bottom. Then add one or two cups of white vinegar to the water and let it finish the cycle.
Sometimes using a dishwasher is an experiment in finding the right combination for hard or soft water, the detergent, and a rinse aid.
Best of luck
BBBBB
Nov 30, 2014 | Baumatic Dishwashers
How to remove front vertical lower control arm bolt spinning freely
These are a pain. If you look up from where the bolt is, it goes thru the body to a big square nut. The nut is supposed to be held by a steel band. A rusty nut and bolt will bend the band. You will need a torch to heat the nut up, (HOT) be careful. Then grab it with vice grips or pliers And start working it out. You most likely have to heat it several times to get it out. Don't cut it out as you won't be able to get the nut out.
Sep 01, 2014 | 2003 Pontiac Grand Am
Howl to fix air condition on 1997volvo960 air only blows to floor
You probably notice that it blows through the dash UNLESS you accelerate hard, then it's floor and defrost vents that gets the air.
It's a ~$40 dual action bellow sort of up over the gas pedal that is malfunctioning. You can put a band-aid on it by removing the kick panel over the pedals and then plugging the yellow line going to the bellow.
To replace it (per Volvo) you have to remove most of the dash! That's expensive and a pain in the behind, plus you probably will have rattles in the dash after.
OR you can cut a hole in the air box where the baffle connects and replace it, then patch the hole with the 'lid' you cut out and duct tape it back on.
Nobody will ever see it. :D
Aug 29, 2014 | 1997 Volvo 960
Need to remove sticky residue from rock saw interior
I would use some sort of degrease product in the system to remove the oil residue . I believe that if you read the instructions it would say when cutting rock use only water to cool the diamond blade . Cutting oil is used only on certain metals to lubricate the saw edges and teeth as well as cooling and never in a concentration above 25% as it affects the cutting ability of the blade. For example concrete cutters use diamond saws and tap water when cutting
Mar 09, 2014 | Cars & Trucks
Lg tone 730 too loud
Here is a solution: Remove rubber ear buds from the device. take a breathable band-aid package. Use two layers of band-aid cut into very small circles..stick the 2-ply band-aid circle to the headphone. Replace the rubber ear bud. This will reduce the sound sufficient to carry on!!
Feb 02, 2013 | LG Tone HBS-730 Bluetooth Headset- Black
Our glasses and dishes have a film on them, which I can only remove by using a calcium-lime remover product on them. The inside of the dishwasher is also coated with a film residue as well. I started to...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 06, 2011 | Frigidaire PLD4460REC Stainless Steel...
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maxdata JOHNSON & JOHNSON / Band-aid brand antibiotic adhesive bandages, assorted sizes, 20/box / JOJ5570 / ... Server Logo
286 people viewed this question
Top Maxdata Computers & Internet Experts
Willem.
Willem.
tim brauer
tim brauer
AnyMHz.com
AnyMHz.com
Are you a Maxdata Computer and Internet Expert? Answer questions, earn points and help others
