Question about Nikon D40x Digital Camera
The camera does not work on continuous focus mode...what do I do?
Shutter button does nothing when pressed halfway, will not focus automatically. It doesn't make the beeping noise, no green box, nothing happens! I can press it all the way and take a picture, but t
Please check if yu did set the camera in AF mode continuous. In that mode, the camera is focusing on whatever is aimed at. Even when the shutter button is not pressed, allowing you to shoot without missing opportunities.
The mode where you see the camera focus when the button is pressed half way, is called single. This setting will conserve battery power.
Look in the manual under Switching between Focus Settings. I can't tell you war page that is for your camera, in mine it is page 100.
On the last pages in the book are all settings for each shooting mode.
Dec 01, 2013 | Canon PowerShot SX160 IS Digital Camera
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
My camera is set on lock, how do I unlock it (fuji s5200)
Are you pertaining to the Focus mode? If so you can unlock it using the Focus mode selector lock switch. Press the Focus mode selector button to change the focus mode.
S-AF- Single AF
M-F- Manual Focus
C-AF- Continuous Focus
I would like to know more information regarding this matter.
Aug 15, 2009 | Fuji Cameras
Continuous auto focus
check and see if the lense is in the macro mode
Jun 11, 2008 | Nikon COOLPIX S6 Digital Camera
What autofocus modes does the DiMAGE A200 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. Full Time AF that continues focusing without pressing the shutter-release button can be used in both AF modes.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What autofocus modes does the DiMAGE A2 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. When setting spot focus point in AF continuous mode, subject tracking can be used. (Subject tracking can be turned on/off by the recording menu. ) When selecting the Spot Focus Point, Full Time AF can be used*. * Full Time AF can be turned on/off on the setup menu. * Sensors mounted on the grip and on the eyepiece detect when the camera is held.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
What is the available shutter speed range?
The DiMAGE A1 controls shutter speed in the range of 30 sec. to 1/16000 sec. in 1/3 increments. (at bulb maximum 30 sec.).
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Is the focus fixed at the first frame in the continuous advance mode?
If the focus mode is set to continuous AF, AF is activated for every frame in the continuous advance mode (including the progressive capture). However, it is fixed at the first frame in the UHS continuous advance mode (including the progressive capture UHS continuous advance).
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Can't take picture with monitor off?
When the LCD display is "off" the focus mode is automatically switched to "Single AF" mode (since there is no way for the user to confirm that the proper subject is focused) and unless focus is locked the camera cannot fire. When the camera is in "Continuous AF" Focus mode the camera will take a picture whenever the shutter release button is pressed, wether or not the subject is in focus. You can take a photo with the monitor off, but the camera will have to lock focus before it can fire and will not respond as quickly as with the monitor on.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon D40x Digital Camera Logo
18 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
