My 1022 jammed. I was able to remove the paper and it is clear. Now, however, the only green light on the right of the printer is the center one. It is a steady green light. The top one that normally blinks is dark. Also, I don't even know where the "door" is nor where the on/off switch is. I did unplug and replug which is where we are now. As you may gather, I am a challenged "senior". Help please.
  • 137 Answers
When you unplugged the printer you flushed the print job from the printer. Try to print again and it should work
Posted on Sep 27, 2009
  • 8,404 Answers
Make sure you got all the paper out. Some times a little piece tears off and will tell the printer it continues to be jammed.
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Jan 05, 2013 | HP LaserJet 1022 Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Triagle light blinks on HP Laserjet 1022
If only the triangle light blinks then is because one of the following reasons:
1.The print cartridge door is open.
2.The printer is out of paper.
3.The print cartridge is installed incorrectly. Try opening the door, removing the cartridge and installing it again. It should snap into place.
4.There is a paper jam. Remove the cartridge and check if there is a paper jam.
Feb 06, 2010 | HP LaserJet 1022 Printer
Hi sir HP Printer 1022 paper jam problem
turn off you print and remove the toner and remove the jam paper and shake then place the toner back and on the printer then you will now restart you system which you place your printer on it will work like that a
Oct 24, 2009 | HP LaserJet 1022 Printer
HP 1022 Printer, OS X 4, printer jam
Unplug it for a minute or so. Make sure all the paper is out. Turn it back on. Macs usually have their own drivers. Did it come with a disk. Please rate me
Jun 18, 2009 | HP LaserJet 1022 Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
HP Laserjet 1022
Try to clear dust from cylinders..
I had similar problem and I cleared dust from cylinders with ear sticks and destilled water.
good luck :))
Aug 12, 2008 | HP LaserJet 1022 Printer
HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
Jan 23, 2008 | HP LaserJet 1022 Printer
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
jasbo
jasbo
