Question about GE Spacemaker JVM1640SJ Microwave Oven
Select Power Level button comes on by itself..!
I have a GE Spacesaver JVM1441 950watt over the stove microwave, and it has been doing strange things, like coming beeping and flashing "select power level" . It also does other strange things, such as beeping for no reason.
We have determined through our trials with it that it is triggered mostly by cooking on the stove, and the steam rising into the microwave. Turning on the fan help for a minute or two then the beeping and the "select power level" flashes. Sometimes we have to unplug the microwave. The problem still occurs though when we plug it back in.
Anyway.. We have also lost the power to the turntable feature. Nothing brings this back.
Any help would be appreciated.
Thanks
Al and Sandra Turcotte
  • GE Master
  • 9,047 Answers
Thank you for posting the partial model number. That narrows it down.
You have a failing membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
On this model series, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Sep 27, 2009
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, This is Mike. My GE spacesaver xl1400 is shutting off as if it has lost AC power seconds after hitting the start button. The last couple of times it reset itself and now its dead. (power source is ok)....
-thermal cutout
-fan/fan motor
-transformer
-capacitor/diode
-circuit board, triac or magnetron
any of these could be the culprit
any of these can be tested
let me know if you need further instructions
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacesaver oven JVM230 quit, like a fuse blew. No over the stove light, no exhaust fan, nothing. I checked the circuit breaker and pluged in an appliance and it worked. The plug is okay. Jim
This is almost certainly a blown thermistor. This device is located at the air outlet on the microwave. This is a thermally sensitive resistor that cuts power if the unit overheats for safety. It can fail because of age also. Replace with the save value unit. You can get this part from electronics stores like Radio Shack.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1640SJ
click on your model number. Then on the next page you can select diagrams to look at.
Mar 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power level
Hi cindeet,
I don't have this particular model, but have experience with other GE stoves & ovens. Looking at the control panel for an Advantium 120 at the link below,
http://www.geappliances.com/products/introductions/advantium/downloads/advantium_brochure.pdf
I'd start by pressing the "Power/Temp" button, and then turn the knob to select which power level.
There is also a Help menu shown (upper left corner of the photo I'm looking at - page 4 of the PDF document referenced above.
Let me know how this works for you - thanks in-advance.
Jon
Dec 23, 2008 | GE Advantium 120 Convection/Microwave Oven
Microwave makes a strange humming noise when it is working - sounds like a vibration of some kind. Does not always happen. Somethings it starts once the microwave has been running for a few seconds. ...
Assuming nothing's loose (such as from past repair attempt) then it may be the magnetron failing.
Your best bet is to keep using but (as always) do not leave it unattended while it's running.
Then if things get worse in some way, that would be a harder failure that can be assessed more easily.
If you are close to the end of the warranty period (1 year parts & labor or 9-year magnetron, e.g.) I would not wait past then.
GE Customer Service is here if you would prefer service now and want to find your nearest GE-authorized servicer.
Oct 14, 2008 | Microwave Ovens
My microwave makes a strange humming noise when it is running. It does not do it all the time, sometime it starts part way through the cooking process. I would appreciate some advice as I am worried...
This could be a laminate plate in a transformer or the magnetron. It is nothing to worry about. If it fails there wont be any excessive damage. The cost to eliminate a noise is not worth it and this problem will not cause any other things to go wrong.
Oct 14, 2017 | GE Microwave Ovens
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
49 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
