Question about Kenmore 24032\24036 Top Load Washer
Need to know how the control panel goes back on
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Your model number will likely start with 110. and then a series of numbers.
A page will come up with a list of sub-components.
Click on the control panel section and you should get an idea of how it mounts.
Another good site is the Whirlpool installation and maintenance PDF for top load washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Sep 27, 2009
How to replace air controller topside
If you need to replace the control panel altogether, there are a few things you should know beforehand. Before you purchase a new panel, make sure it's compatible with your existing spa control pack. There is often a part number on the existing top side panel when you pull it out of the housing. A sticker is typically on the side indicating a part number from the manufacturer. Otherwise, get the number for your spa control pack and call the manufacturer to find out which top side panel will work for you.
Replacing a topside control panel is a fairly simple process. First, turn off the power to the unit. Remove the spa access panel and take the cover off of the control box and unplug the wire that goes form the topside panel to the circuit board. Gently remove the topside control panel. Remove the plastic from the self-stick backing of the topside controller. Place the topside controller in the place of the previous one. Plug in the topside wire to the circuit board and power back up the spa to test the function of the new unit.
Mar 31, 2017 | Pool & Spa
Volume Control
Look for any jammed buttons (keys) on remote control and/or on control panel.
Aug 12, 2012 | Televison & Video
Control panel on my Maytag MEW6530DDS not working / how do I open the panel and replace it?
there are screws that hold the frame that holds the panel in place. they are usually 3 at the top of the oven. after removing them you take that piece off and you then take out the other screws that show themselves. it is kind of like a puzzle. one suggestion is to make a crude.drawing on cardboard of the oven and stick the screws thru the cardboard and then you will know where they go when you put it back together. learned that trick the hard way. and make a drawing of the back of the oven control board and make a diagram of it that shows where each wire goes so you will not get them mixed up when you put the new one in. we had to order the wiring harness that goes from the control board to the oven thermostat. it was back ordered for 3 months. if i had not made that diagram i would have been lost when i went to put it back together. went online and found an oven control board for $120 installed it and the oven has worked ever since. this oven has a bad setup that channels the heat right by the oven board and it ruins the control board.
Jun 21, 2010 | Maytag MEW6530D Electric Single Oven
F7 code keeps coming up on the digipad screen. timer goes on and off by itself. even when unplugged and then plugged back in, still happens.
The F7 code is due to a stuck button on the touch panel or a bad control module. You will need to unplug the range and remove the back panel. The first thing you will need to check is that the ribbon connector that goes from the touch panel to the control module is seated correctly. If it is found seated correctly then you will need to remove the ribbon connector and try cleaning the contacts with an eraser then re-install the connector and power the range back up. If the error code comes back then you will need to determine if the touch pad or control module is defective. You can do this by disconnecting the ribbon cable and power the range back on. Then wait 24 hours and see if the error comes back. If it does then it is the control module(ERC) and if it does not then the touchpad is the problem. Doing this work will require you to remove the back panel of the range. Make sure that you do not work on the range when it is plugged into the electrical outlet. You can be injured or worse if you attempt to make repairs on the range and you do not know what you are doing.
Apr 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites like--repairclinic.com and applianceparts.com
thanks.
Aug 28, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Control panel error
On most Jenn Airs, this means a key on the keypad is stuck. Try shutting off power, inspecting the keys to see if one looks stuck in or feels worn out. Rapidly press each key several times to loosen and clean the contacts. Turn the power back on and see if the problem goes away.
If this fails to help, you will probably need a new keypad for the unit. I don't know what model Jenn Air you have, but you can find parts for most Jenn Air models at Appliance Parts Pros. This is probably an easy fix, but if you are not comfortable or do not know how to safely work on appliances, you may want to call in a qualified tech.
Jan 09, 2009 | Jenn-Air Ovens
AC when you first cut in on, blows cool air then the next thing you know it is blowing hot air. The lights go out, and I tap it, it comes back on and again blows out cold air. This goes on the whole time...
Dude, everyone has this problem. It's the wiring on the back of the climate control panel. If you look up this issue with the climate control panel you will find various links to diagrams of how to fix this issue. The original soldering on back of the panel gets loose and the simple cheap fix is to un-solder it and re-solder it. Then everything will work 100% and even your interior lights with brighten. -neoblis
Jul 25, 2008 | 1992 Honda Prelude
Warsher panel goes wacky......
Sounds like you possibly have a short in the touch panel unit.  Very hard to know for sure, but that is usually the signs we get when one goes out.  The problem is this touch panel is seriously expensive.  Try this, unplug the machine for around 15 minutes.  Sometimes they can hang up.  Unplugging it would cause the computer to sometimes reset itself.  If it does the same thing when plugging it back in, its that touch panel.  You cant always see any burned or scored areas to indicate a bad board.  Good luck and let me know if you need any further help.    Jim
Oct 23, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
