Question about Jenn-Air Ovens
I receive an F1 error notice when I cancel the bake setting.
  • 725 Answers
Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
if you are handy you can remove control board ribbon clean in and replace..
Posted on Sep 27, 2009
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F1 error relay circuit failure
Hi This is the Alarm system watchdog circuit :
The system has detected a failure in the internal watchdog element , relay circuits and will atcivate a cancel feature. F1 will be displayed in the time digets and will beep until the cancel button or another funtion is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure the ERC is picking up a comand to supply heat without receiving an input from the membrain. The watchdog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control ERC board.
Dec 09, 2011 | Dacor MCS130 Millennia Electric Single...
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Jenn air wall oven control panel not working properly
You will need to replace the front control board and the touch panel
Mar 28, 2017 | Ovens
Whirlpool oven timed bake feature dosn't work.
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 25, 2009 | Whirlpool RBS275PD Electric Single Oven
F2 & f3 alert
thank you for the info. you need to replace the oven sensor. an F2 error is oven is to hot. an F3 error is a shorted or open oven sensor. the oven sensor is easy to change, and not very expensive. if you have further questions, let me know. shane
Aug 24, 2009 | Ovens
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
What does the F1 alert mean?
Hello jiverson,
Welcome,
You said, your get a recurring F1 beep even after I press "cancel" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
Please send me your complete model number including the single diget at the end of the model number.
For example: FGB24S5AW1
Then I can be sure!!!!!!!!!!!
Waiting your response. I'll check for it through out the day!
And get back to you as fats as possible so you can take care of it Monday!
Huuum
In some ovens It could be failure of your, EOC (Electronic Oven Control) failure
Oct 19, 2008 | Frigidaire FGB24S5A Gas Single Oven
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Aogd2750e gas double oven
F1=Electronic range control failure
It is telling you may have a faulty control...need to replace control or EOC
Thanks
Dec 07, 2007 | Amana AOGD2750 Gas Double Oven
Ovens Logo
77 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
