Question about HP PhotoSmart C4280 Laser Printer
My c4280 say: ink cardrige are damage or absent
Can't obtain correct color prints - all images appear with too much blue
please do a nozzle check
and make sure the cadriges and original ones.
Jun 30, 2008 | Office Equipment & Supplies
My mp500 probably has a print head alignment problem everything prints green
Take off all your Cardrige and bang it up on a plane paper see if color ink stick into your paper if not change your Cardrige
Sep 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
HOW DO I INSTALL THE INK CARTRIDGE IN PHOTOSMART C4280
Turn on power to printer, then lift the top half of Printer lid, the cart holder will move to centre, place printer cart in the holder rack, press firmly in place.
Jun 07, 2010 | HP PhotoSmart C4280 Laser Printer
Prints coming out green and orange
the print head is defective or ink cardrige is defective, (perhaps is non original replace ink cardrige)
Dec 20, 2009 | Canon i9100 InkJet Photo Printer
My HP C4280 won't recognize the ink cartridge.
Are you using aftermarket of refilled cartridges? The electronic chip may be damaged so that the printer cannot sense the cartridge. Try using a new OEM cartridge. Chances are that the problem will go away. If it does, take the faulty cartridge back to where you got it and ask for a replacement or a refund.
Nov 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Substitute ink cartridges no longer work
I have the same problem and many Canon users , i try a trick that mayby solve this and last but not least ... Mayby the only cheap solution for all print users !! jumping-smiley-004.gif
My problem .. was looking for a cardrige solution ( IP4300 ) because 4 (of 5) cardrige leds are dimmed off and need to be replaced . I just order 5 adopters and 5 new with chip for all the five cardrige . Problem : The chip uses memory and that makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is new, experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need all 5 brandnew cardrige with chips ( please keep all ink preventions inplace )
B - You need is a 4 poles - 1.50 / 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - 5 old chips for adopting the connection outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of 1,5 / 2,5 meter a 5 pcs of 30 / 50 centimeter
2 ) Solder on each lengt a old chip (this is functioned as a adopter) but first remove all the (useless) electronic components and place them on the cardriges
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our make a alternative contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the empty old chips ) in the right ink location(s)
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for arrive of the new ones, anybody who try make a handshake !
See you soon
John
Netherlands
Jan 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon Pixma MP780 Printer - black 3e fails to print
installed a new Print-Head, but that was no changes. I use refill ink, and it seams the BlackInkTank is not exactly on the Printhead and it is Air in the Pipe, i take the Printhead and the Ink-Cardridge in the Bathroom, and press the Ink-cardrige on the Printhead and take a hard breath and blow in the Air-Holes of the Ink-Cardrige until black ink come out of the Printhead, reinstall in the Printer, end it works well.
sorry about my bad english
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP PhotoSmart C4280 Laser Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
