Question about Garden
Need gas/oil ratio for 10 year old bx90 leaf blower
    Problem Solver:
  • 12 Answers
A safe ratio for any 2 stroke engine is 32:1
Posted on Sep 27, 2009
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Where is the button to open fuel cap on a chrysler300 year2006
This question needs to be recatagorized... Chrysler does not manufacture leaf blowers.
Jul 17, 2012 | Homelite Gas Fuel Cap Blower Bp250 Bp250i...
Need gas mix
check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Jun 03, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Primer bulb on my craftsman leaf blower #358797342 wont prime
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
Dec 30, 2011 | Craftsman Garden
My craftsman 32cc leaf blower won't stay running
Nov 06, 2011 | Craftsman 4 Cycle Blower/Vac
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
Runs 10 or 20 seconds and simply dies
Hello. I recommend that you install a new spark plug and put some carbeurator cleaner in with your gas. i like a product called seafoam. just follow the directions on the container.
Nov 24, 2009 | Husqvarna Forest & Garden #965102302...
Need a Manual for HomeLite Leaf Blower Vacuum Model Ut08934B, specifically for fuel mixture ratio.
Most 2 stroke engines.......99% now use 50 to 1 mix in the fuel.
Others are close to this ratio.
Older....over 20 to 30 years old ........that may have had 20 to 1 ....or other ratios run happily on a 50 to 1 ratio using the newer 2 stroke oils.
And......BONUS.......they have increased engine life because of reduced semi burnt oil build up caused by "too much oil".......particularly around the rings on the piston(s) etc.
Aug 31, 2009 | Homelite Garden
Homelite broom help I put way too much oil in now it's smoking!
i agree finding the ratio is no as easy as it should be. yes. drain the tank. don't use the old gas somewhere else. use fresh gas & mix ratio in separate gas can or container. use a bit of ether/starting fluid into the air-filter inlet opening help fire it up. a new plug is fairly low cost and easy and that might also be needed after the oil bath and 3 years.
Nov 03, 2008 | Garden
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
