Question about GE Profile Harmony DPGT750EC Electric Dryer
Dryer drum turns but no heat. Checked fuses and
Dryer drum turns but no heat. Checked fuses and all are good, checked outlet and plug, all are good. Checked exhaust vent and lint screen, no blockage. Suspect maybe a temperature sensor, heat element or heat fuse
  • GE Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
879hftg
Posted on Sep 29, 2010
Replaced all parts for dryer because of no heat dryer runs drum turns had breaker and wiring going into dryer everything ok still no heat could wires be backwards going to replacement parts?
Electric dryers have as many as three thermal fuses. See if you might have missed one. One next to coils, one next to drum and one near the lint trap at air outlet. All three have different trip settings.
Jan 04, 2016 | Dryers
No heat
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 10, 2014 | Dryers
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Dryer is cool not getting hot?
1. Close the dryer door and press the "Start" button for at least one second. Some dryer brands require the button to be pressed for several seconds. If the drum tumbles, you can eliminate the possibility of a problem with the electrical circuit that supplies the motor.
2. Check all the connections on the back of the dryer. Many dryers have two electrical circuits--one for the heat and one for the tumbling motor. If the motor works, but there is no heat, check to see if the larger plug is plugged into its receptacle. Your dryer may have two plugs--one small regular household plug and one larger 240-volt plug for the heat. Both must be plugged in for the dryer to work properly. The larger, three-pronged 240-volt plug will not fit in a normal household outlet; it needs a special dryer outlet. The plug cannot be cut down to fit.
3. Check the circuit breakers or fuse panel if the dryer runs but there is no heat.
Jan 14, 2011 | Maytag PYE2300AY Electric Dryer
A Kennmore electric dryer, model 697267. Heating element checks out ok. Soninlaw said breakers are ok. Dryer drum turns but no heat? I'm 640 miles away, is there a thermal fuse in the circuit.
Yes there is a thermal fuse and a hi limit switch. The hi limit switch is attached to the heating element casing. You said the heating element checks out If you checked it with an ohm meter and it checked out good. If you checked it visually double check it. The hi limit can be checked with an ohm meter it should show continuity. If you dont have a ohm meter you can jump the wires by connecting them using a paper clip or copper wire. Make sure to tape them with electric tape. The thermal fuse is connected with the Heating element and hi limit by one wire and is located at the bottom back of the dryer and slightly to the right as you face the back of the dryer. It is a small two wire fuse and once it trips you have to replace it you can check it and test it just like the hi limit switch. Be careful and always unplug the dryer before starting any repairs. I hope this help. If you need me to clarify anything just let me know. good luck
Aug 25, 2010 | Dryers
Dryer will not turn on. Checked outlet with
unplug dryer and take back panel off. plug back in. use caution your working with 220v. get a reading on power cord where it connects to dryer. if your good there look for a micro fuse, two small wires connected to it very small component. sounds like you have a bad power cord or power surge popped micro fuse. good luck and be safe!!
Jan 09, 2010 | Magic Chef CYE3005AYW Electric Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
110.67832794 dryer will not heat
Check the thermal fuse. No continuity means a bad fuse. Part costs around 10 bucks no more.
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag Model PYE 2300 AYW Dryer will not Start
How about the controller that turns everything on? Check for power to it? Relays(if any) working?
Aug 28, 2017 | Maytag PYE2300AY Electric Dryer
GE Profile Harmony DPGT750EC Electric Dryer Logo
169 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
