Question about Thetford Norcold RV Cooler/Freezer
Norcold Model 682 problem
I have electricity as far as the outlet the refrigerator plugs in to, but none of the lights come on above the fridge to indicate I am getting electicity that far. The fridge worked fine on electicity three weeks prior. We have never used the propane side of the fridge. The switch from auto to gas is hard to move and doesn't feel like it has a positive stop at each position. Is there a likely problem with the switch making good contact?
    Problem Solver:
  • 15 Answers
No these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Posted on Jan 29, 2010
  • oscar armendariz Sep 19, 2010
    i have the same frige the 682 and its has the same problem..its getting power to the circut board but its still not operating...all fuses are good...what could be the problem?
I have a Winni Minni with Norcold refrigerator 682. I have change board and element,but its not working on electric only on gas, prpblems ?? I live in Norway.
Sounds like your selector knob may net be making proper contact with electricity. You have changed everything else. You could check power available with a multimeter to your element. If power not available to your element, back trace to source and check for burned wires or breaks in wiring.
Hope this helps!
Apr 18, 2016 | Refrigerators
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Were are the fuses located on a norcold 682 unit
They are located on the circuit board on the back side of the unit under the black plastic cover.
Jun 30, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold 682 is 0 in freezer and 50 in fridge cranked all the way up over 48 hrs now where do i look now
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Apr 15, 2010 | Thetford Norcold RV Cooler/Freezer
Fridge will not work in gas mode.
You mat have to clean the pilot light and the ignition lube. Spiders like to build nests in the tubes which obstructs the proper gas flow.
Sep 04, 2009 | Dometic RM2652 Refrigerator
Was camping all weekend... frigerator was fine, brought it home and plugged it in and all electrical works fine, but frigerator is dead. none of the lights come on (auto, off, gas) no cooling. How can we...
This can be a problem on the control board or in the control switch, you better check this first..
For clarification may I know what model/maker that you have?
Thanks
Aug 31, 2009 | Thetford Norcold RV Cooler/Freezer
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
Norcold model number N621 won't power on
its difficult to explain the dc are going to the thermostat and from the thermostat to a element that warms the outside to make cold in the inside does it have a pc board or not be free to ask questions
May 26, 2009 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
591 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
