Mitsubishi HD1080 Medallion TV
After a few minutes, sometimes after an hour or two, the tv picture goes bad. It looks like the colors go off kilter on the outsides. It looks like it the picture bends in from the sides and from the top and bottom. If I turn it off and on it's still bad. It's only good the first time I turn it on that day. Is this an easy fix? Could there be an adjustment I need to make or possibly a part that I could replace myself?
  • 5 more comments
  • JoeD1 Dec 18, 2007
    I don't know what you mean by self test.
    I am not home in front of the tv, so I don't have the exact model number. Could you give me an idea of what it could be and if I could fix it?
  • dawnkey Jan 06, 2008
    I have the same problem!!! I will try to find out how to do a self test.
  • Carky Jan 27, 2008
    I have the same problem. The picture starts to bend and becomes distorted. After a short time it pops back into focus. Lately it takes much longer for the picture to come back into focus. Also I am getting "crackles" or "multiple XXX's" across the screen when the picture bends. Is this problem fixable or should I just get a new tv?
  • Mike Behan Feb 22, 2008
    Same exact problem here.
    Same problem here.
  • Anonymous May 03, 2008
    no pic till tv warms up
  • Big huge joe May 06, 2008
    same exact problem and TV. I have gone into the advance setting and tried to work the converge the blue and red converge will adjust side to side but will not adjust up and down. Once in a great while the re-set to factory option works
    Genius:
  • 1,153 Answers
Do the self test and return with model number and I can help.
Posted on Dec 18, 2007
  • Edward Acuna Dec 11, 2010
    I have the same Mitsu TV and a similar problem, picture "bows" on top
Have a Mitsubishi medallion 65 in got a code 2-3 how do i fix this or is it worth it?
These Medallions have some of the worst problems caused by wiring faults. They over heat and go into sleep mode. Try getting a can of compressed air and cleaning out the dust.
Chadman
Nov 18, 2014 | Mitsubishi LT46164 Unisen Medallion 46...
My Mitsubishi HD1080 series screen is coming inward from the top & bottom.. and occasionally red & green lines or black lines will flash through it... It started out just being inwards once in a...
You have either bad convergence ICs or just bad grounds on the IC. I would go ahead and replace the ICs and check those small ohm resistors, as you have to pull the signal board out anyway. For futher instructions see the website www.TvRepairKits.com. They may have what you are looking for. Be sure you have the TV model number next to you. Thanks for asking and show a few hands of support!
Nov 07, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Blurry picture
convergence problem...very common. An excellent TV, well worth repairing!
Jun 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Sep 17, 2009 | Samsung Televison & Video
Picture goes bad (fuzzy&scrolls&lines) on Hitachi projection tv
Sounds like your convergence modules have gone bad. They have 21 close spaced pins to unsolder and resolder. You'll need a soldering iron with a fine point tip and thin gauge solder to do the repairs yourself. Solder bridges between pins are common when soldering these module pins, so have some unsoldering wick handy if you're going to fix it yourself. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 14, 2017 | Hitachi 50UX57B 50" Rear Projection...
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Mar 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
546 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
