Question about Kenmore 24032\24036 Top Load Washer
Fills with water while lid open will work like suppose to when i
Turn dial pass water fill selection
  • Kenmore Master
  • 8,404 Answers
In my experience, washers will fill with the lid open but will not run with the lid open.
Did you have specific question?
I hope this helps you ..
a
Posted on Sep 27, 2009
Washing machine
possible bad or burned contacts inside timer assembly
Dec 27, 2007 | Washing Machines
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Our washer is filling with water but will not run the cycle after it fills. We were able open and close the lid and it would start but now it only fills with water...Please help!!!
the lid switch is buggered the lid can be open while its filling but when it goes to start washing the lid needs to be shut so the lid switch isnt working so the machine thinks the lids open.
Jan 05, 2011 | Maytag Washing Machines
Washer filled, did wash cycle, would not drain, spin?.Could turn dial to rinse and would agitate, but never pump out water or spin?.
That usually is the lid switch. You should hear a click when you open and close the lid. If this is a Whirlpool, Kenmore,Maytag washer, you can get the part here.
Nov 22, 2010 | Washing Machines
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kalvinator smart drive 085 not filling with water when start button depressed
Could be the magnetic latch on the lid that tells the machine when its closed you can by pass the switch just dont open it whilst its going
Jul 12, 2008 | Washing Machines
No water
Your problem sounds like a fill valve problem. This is what your fill hoses connect to on the back of your washer. It is an electric solenoid valve that is supposed to open when filling. However, sediments from hard water and well water have a tendency to clog them up to the point where they don't pass water any longer. Sometimes, the solenoid itself goes bad. A new valve usually runs about $20-$30. If you've checked your fill hoses and verified the household valves are working, then I recommend replacing the fill valve assembly in the washer. I hope this helps.
May 20, 2007 | Whirlpool AWM5104/1 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
