Question about Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515
Only problem, I need an owners manual for Porter Cable air compressor model CPF4515-2
  • 47 Answers
Here ya go. Dewalt now owns Porter Cable and Delta so they have all of the manuals and parts diagrams on their servicenet site
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/A08202-E.pdf
Posted on Apr 07, 2010
How to test electric switch on porter cable air compressor
What you need is something called a volt-ohm meter.
Obtain one and use it to test your switch and wiring.
May 26, 2014 | Porter Cable C2002 150 Psi 6 Gal...
My porter cable 5101 air compressor will no build up pressure.. no visable leaks found
use liquid soap in water to check for leak if you have no bubble at any connection you probably need a rebuild kit for pump,this model is oilless and wear fast
sometime the o'ring on pump output pipe is worn,you need to open head of the pump to see it
Nov 12, 2012 | Porter Cable - Cable C5101 Oil Free...
What type of oil do I use in model CPLDC 2541S
If you mean the CPLDC2541S (Porter Cable air compressor), you need to fill it with an air compressor oil. The recommended weight is SAE-30 (API GC/CD heavy duty motor oil). You can use a SAE-10 oil in harsh winter condiions. The manual is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/20237/PORTER-CABLE-Air-compressor-L0309172 .
I hope this helps.
(note standard motor oils designed for cars are not appropriate for a compressor.)
Jun 21, 2011 | Porter Cable Garden
My porter cable pancake PSI 150 keeps running will not shut off
The compressor has a max psi setting of 150.If the pressure is not reaching this or is only stabilizing at a low pressure you have an air leak around a gasket somewhere.If it is reaching 150psi and not shutting off your pressure switch is bad.Replace it.Check your owner's manual for a part number or go to www.factoryauthorizedoutlet.com to find the part.
May 05, 2011 | Porter Cable Air Tools & Compressors
Porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Jun 04, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
Need owners manual for Porter Cable FN250C 16 Ga. nailer
Here's a link for PDF file download of your manual.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/N027636,DA250C.pdf
Apr 15, 2010 | Porter Cable 16 - Gauge Finish Brad Nailer...
I received no manual for my 60 gal. Porter Cabel air compressor (model #VT627504AJ) and I need to know the spec. for wiring.
being that its 220 on the compressor Is where I assume you are wanting to know where the wires go? There should be a terminal strip or box that has a terminal strip by each terminal there should be L1 L2 and either ground or neutral. The two hot wires one each go to the Line terminals and the ground or neutral to marked terminal.
Jan 09, 2010 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Trying to wire up my new air compressor, need help with wires.
If you are trying to connect power lines directly to the motor then stop what you are doing, I advise you refer to the owners manual for correct wiring of the compressor. I would highly advise that you seek the service of a professional to hook it up. otherwise you could damage the equipment or worse yourself.
Dec 09, 2009 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
Porter Cable Cable 135 PSI, 15 Gal. Oil - Free Horizontal Compressor CPF4515 Logo
378 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
