Question about Amana Side by Side 20.6 cu. ft. Cabinet Depth Refrigerator ARS9169A
Crud (mold?) in water from refrigerator dispenser
Have an older model Amana side by side, but have noticed tube like gray matter in drinking water- looks like in the tubing not the filter?
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
SOURCE: amana side by side ice dispenser leaking water
icemaker wont dump ice
Posted on Jun 19, 2008
rickzilla
  • 706 Answers
SOURCE: amana ic6 ice maker
sounds like your ice maker is working properly and that maybe you pinched the water line when you reinstalled it back into the elbow.. is the elbow clear of any ice build up or foreighn matter that would restrict the flow of water into the ice mold tray? If so..that's your problem.. ( thaw it out or melt it and then you should be OK) Hope that helps..
Posted on Aug 19, 2008
smartr10U
  • 1305 Answers
SOURCE: The tubing for my Amana SRD25S5L is brittle and
If you're refering to the ice maker supply tubing, you can get ice maker hookup kits with the proper tubing and ferules at a local hardware or plumbing supply house.
Save your fittings as you pull them off to reuse what you can, you may need to replace the compression ferules on the plastic line under the compression nuts.
Be sure to pressure check for leaks before moving the refer back into position.
Posted on Jul 13, 2009
  • 128 Answers
SOURCE: water tube to drinking water disconnected at back
if you also see wires dangling, then the water shutoff valve is missing, otherwise, my guess would be an inline water filter is missing.
It might just be a simple water line coupler, but I would look at a parts diagram to be sure, or take a peek at a similar model at an appliance store.
http://www.repairclinic.com/Amana-Refrigerator-Parts
Posted on Oct 23, 2009
Why does my drinking water from the auto water dispenser smell??
In some instances when the cool water and/or ice maker is not used for some time, mold can accumulate in the tubing between the water intake and the ice maker. Once this happens, it is very difficult to eliminate. One method is to disconnect the tubing from both ends and block one end off. Then fill the tubing with bleach or half bleach and half water and let stand for just a few minutes. Then drain the bleach from the tubing and flush the tubing thoroughly. Be sure to run adequate water through the system to completely eliminate the residual odor/taste of the bleach before reconnecting.
Sep 21, 2014 | GE Monogram Side by Side Refrigerator
My side by side Amana water dispenser no longer
you have a kink in your tubing test by checking at pump which is visable by taking back felt cover at bottom where water tube goes in cut a few inches away from pump to see if water flows when you activate swich if so you have a kink in your system to repair the cut they have couplings in the store
Mar 22, 2010 | Amana Refrigerators
Water tube to drinking water disconnected at back of frig on floor there ware two tubes dangling, is there a device that comes between the two ends.
Oct 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Mold in water dispenser tube
Your refrigerator has a filter system below the bottom and behind the kick plate. Two or three times you need to turn the water supply off to refrigerator and fill the old filter with clorox to kill the algae growing in the storage tank and after you finally get this out and purge the chlorine from system will you be able to use the ice or water to consume. I know this seams harsh but really there is very little else that can remove this without changing the whole water system. Once this is done change the filter regularly and this will help, click on link below and place your model number into the model search feature. This will give you pictures of the parts and there location. Let me know how this goes, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 23, 2009 | Whirlpool ED5FTGX Side by Side...
The water that comes out of my refrigerator tastes musty.
That is the resivor and that black is mold. Time to replace it, although you could try cleaning it.
May 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
KitchenAid Refrigerator water tube needs replacing
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
Please send me your model number so I can give you better instructions. Clorox in the water supply and waiting until the Clorox is cleared from water dispenser and Ice will also do the job!
Apr 04, 2009 | Refrigerators
Kenmore refrigerator water dispenser problem
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
23 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
