Question about Archos 705 WiFi Digital Media Player
It just stopped working, it wont recharge and there is not a whisper out of it? Please tell me if it can be repaired
UNPLUG POWER AND PULL OFF THE BATTERY. IT SHOULD HELP. IF NOT, TRY AGAIN COUPLE OF TIMES. IF STILL IT DOESN'T COME BACK, UNDER THE BATTERY YOU HAVE A 'RESET' BUTTON, BUT AFTER IT COMES BACK IT MIGHT ASK YOU TO RE-CALIBRATE THE SCREEN. GOOD LUCK!
Posted on Jan 12, 2010
Chamberlain 1/2 hp opener stops intermittently during travel.
could be that the remote operation or cycle operation needs reprogramming as it indicates that the program has a corruption in it and the action is lost by that corruption
follow the user manual and do the reprogram sequence
Jul 09, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
My system malfunctioned and some how the software driver was uninstalled. now it wont install telling me the spooler service is stopped. please help
Hello, Please try repairing the operating system and then try installing the software again. If it does not work, then you have to reinstall the operating system.
Mar 26, 2011 | Lexmark X4270 All-In-One InkJet Printer
Extreme fluctuation of TV sound leval drives me nuts!!!!
arn't all french movies in whisper and dark screen mode?
I suggest using an amplifier ( yes an amp) reduce the volume on TV to just audible and plug in xtension line to an amp and set the volume on it. It is probably a faulty sound board in your unit. The use of an external amp will control it better by the audio out line.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Transparent French TV Commercials, Volume...
The belt on my Chamberlain Whisper Drive dipping
Where the belt attaches to the trolley carriage which attaches to the door there is a black adjustment nut with a spring on it. Tighten it up more by turning it clockwise until the belt tightens up. The belt will droop a little when the door is all the way shut normally but should not during operation. If you tighten it up too much the belt will slap on the rail during operation. Make sure the spring is set on the adjustment screw too. This holds the belt tight over time. Thanks BB
May 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
How do I clean a flame sensor on a 1993 Lennox Whisper Heat furnace. It heats,then the gas valve clicks and the flame briefly stops and starts again then the valve clicks again and the flame briefly stops...
You can sand the flame sensor but it sounds like another problem. Sounds like a limit switch or something in the control circuit, You need to have a service tech look at this. Ask for free estimate on repair. I have worked on hundreds of these units and they are sometimes tricky to work on. Lenox has come up with new controls for the whisper heat furnace to replace the old ones. If the flame sensor is bad the unit will try to light a few times and lock out and you ahve to kull power to the furnace to reset. If this is whats happening clean the sensor nd you should be ok If not you need help from a service tech.Rus
Nov 11, 2009 | Heating & Cooling
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Archos 705 WiFi Digital Media Player Logo
172 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
