Question about Refrigerators
I hav a whirlpool et18lk refrigerator thats leaking on the inside and its too warm
  • 213 Answers
SOURCE: RE- WHIRLPOOL NO FROST REFRIGERATOR NOT WORKINK NEEDS SOME HELP
whirlpool has a problem with the relayoverload thats plugged into the compressor. unplug the frig for about 5 min. then, while standing behind it plug it back in and listen. if you here a hum then a click, then you need to replace the relay overload. remove the back panel. the relay overload it plugged in on the left side of the compressor. very easy to replace
Posted on Nov 29, 2007
SOURCE: Leaking Whirlpool refrigerator
I had a problem with water accumulating on the first shelf and and underneath the drawers in the bottom of the refrigerator. I traced it back to the overflow cup that is located inside the refrigerator in the middle of the top. NOT inside the freezer, but rather in the the refrigerator portion.
Unload the top shelf and place some paper towels near the back of the shelf to catch about a 1/2 cup of water. Gently grab the tab on the overflow cup and slide it towards you. I am willing to bet there is a large plug of mold inside the pipe on the cup that has been blocking the drainage.
Now is a good time to clean up the water under the drawers in the bottom of the fridge and while you are at it, clean the shelves.
Posted on Jun 01, 2008
  • 236 Answers
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Posted on Apr 09, 2009
Sea Breeze
  • 4654 Answers
SOURCE: leak inside and outside
Most times this is because the drain from the defrost is blocked as it goes down to the pan under the refrigerator. I am placing a link that can help you solve this problem. sometimes on different models the cause may be in a different place so let me know what you find. Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Posted on May 31, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool refrigerator leaks inside
HI, First thing you do is remove the floor panel of the freezer. Do you see ice?
If there is ice, remove the rear wall of the freezer as well and start removing the ice. There will be down inside the drain hole also. A hair dryer works great for this project.
Please do not use sharp object/tools.
Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Thanks
Vic
Posted on Jun 20, 2009
Leaking Kenmore Refidgator
What is your model number? Sears Kenmore numbers look like this 321.2468102 I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil. Your refrigerator defrost on the average about every 8 hours so the water that accumulates during defrost has to go somewhere right? Yes the water is supposed to drain down a small drain line to a pan down near the compressor where warm air from the condenser fan will blow warm air over the water and evaporate the water again an put it back into the air inside your home, office or wherever your refrigerator is located. Over time that little drain tube gets slime, algae and a gooey white paste gunk that fills the drain line sides up stopping the waterflow downward to the condensate pan below refrigerator. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. Gunk is an accumulation of algae slime and just crud that appears from nowhere in a refrigerators defrost condensate drain line. How a refrigerator leaks is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example of a ET18PKXGTO Whirlpool refrigerator leaking water into a cup below the freezer compartment. Click here=> Whirlpool Leak Photo taken by TechnicianBrian. TechnicianBrian.com. And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Jun 19, 2013 | Refrigerators
I have an 110 year old Whirlpool Side by Side Refrigerator ED27 model. Freezer was leaking on the floor and everything inside was melted. The refrigerator side was also warming. I finally took...
I wouldn't have thought so. It, being a Whirlpool, probably needs re gassing but as the radiator is aluminium and porous, you could be looking at a replacement fridge freezer.
Jan 23, 2011 | Microwave Ovens
The molding inside each door is very warm, the outside of the refrigerator is cool. I have a side-by side whirlpool, model ED22PQ. The center strip inside is very warm as well.
That is what is known as "Anti-Sweat" heaters to prevent moisture accumulating on the doors.
Usually there is a switch labeled "Energy Saver" which allows you to turn them off.
Nov 14, 2010 | Whirlpool Refrigerators
Whirlpool model ed5fhgxkq03 side by side. Lights
check your temp controll to make sure it isnt broken or open circuit also your defrost timer could be stuck in defrost! next check your compressor for running and see if it is hot!! or just warm? if it is just warm and cycling /running then your low on freon due to a internal leak
Jan 14, 2010 | Whirlpool ED2FHEXN Side by Side...
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Is there a drain hole in the freezer area on whirlpool model # ET18LK?
To get to it , remove the food from the freezer and remove the ice maker , if equipped , and remove the 2 screws holding the freezer bottom "panel" . Remove the 2 or 3 screws holding the rear freezer panel on , and remove the panel . About in the middle , under the coils , is the drain hole . If iced up , defrost the hole with a hair dryer until visible . Hot water will help defrost the hole . When water starts to flow , use a small piece of hose , inserted into the drain , and blow thru until clear . This will remove any debris built up in the unseen drain line .
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaks inside refrigerator also the temperture is warm and the freezer is in hyperdrive.
that sound like low gas in the system because the freezer is working but the fridge not
Jun 01, 2009 | Whirlpool ET8MHK Top Freezer Refrigerator
Apr 09, 2009 | Whirlpool ET8FTEXM Top Freezer...
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
