Question about Espresso RMI La Cimbali Espresso Machine
We have a La Cimbala M2 barsytem that indicates press cleaning button, where is it?
    Problem Solver:
  • 18 Answers
The top left button on the 2nd row of smaller buttons. It has a filled cup as an icon. press and hold until screen says 'short wash' or group wash. There is also a full cycle washing that is required some time during the day usually at night or start of a work shift. This requires the opening of the 'de-cafe' or pill drop chute. It's a small black slide about the size of a pack of gum. open it and drop a cleaning pill then close it. the panel buttons will blink and the screen will say press cleaning button. press and hold the wash button (as previously mentioned) till the cycle starts to clean. Release button and allow 8 mins for the cycle to complete. This will keep the 'clean cycle' clear until the next shift or next day when it needs to be done again. These instructions should be in your manual that came with the machine.
Posted on Feb 10, 2010
What is solution for konicaminolta 164 maitanance call m2
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.
1-Press utility button on panel.
2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.
3-its the code to get into service mode.
4-After pressing above mentioned buttons you will enter into service mode.
5-Now select service choice option.select it by pressing OK button.
6-In service choice option you will see Maintenance count option.
7-Select it by pressing Yes or OK button.
8-There will be three options 0,1,2.
9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Jul 04, 2014 | Konica Minolta bizhub Office Equipment &...
Cimbali M2 wont deliver coffee
Coffee may be to fine. To Check, open pill door and press any blinking button. If water comes out then for sure the coffee is to fine.
Nov 30, 2011 | Espresso RMI La Cimbali Espresso Machine
How do you set the time and date on blood pressure monitor model DS-1902
Use memory M1 button to increase the flashing year and memory M2 to decrease the year. Press START button to confirm and go to the next step. Day flashes. Press M1 or M2 to adjust and then START to confirm. Month flashes. Adjust with M1 and M2 buttons and then press START to confirm. Hour flashes (the clock operates in 24hour mode). Adjust with M1 and M2 buttons and then press START to confirm. Minute flashes. Adjust with M1 and M2 buttons and then press START to confirm.
The clock is set and the unit is turned off.
Please rate if this helped. Thank you
Jan 15, 2011 | Mark Of Fitness DS 1902 Blood Pressure...
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Dec 17, 2010 | Minolta bizhub 180 Black and White Copier
The grinds are too course on my La Cimbali M2 Barsystem. Where is the lever, and how do you move the lever in order to make the espresso grinds finer?
The ginder udjustment for M2 is behind the coffee bean hopper. It is a small level hundle. You have to pull it up and rotate it step by step clockwise for more fine.
May 08, 2010 | Espresso RMI La Cimbali Espresso Machine
M1 and m2 are in top left corner. How to undo it?
Press 0 [STO] 1 to clear the Memory M1. Indicator M1 will disappear.
Press 0 [STO] 2 to clear the Memory M2. Indicator M2 will disappear.
Dec 15, 2009 | Texas Instruments TI-30XA Calculator
Display says to press cleaning button. Which one is it?
Top 2nd row left. The small button with the filled cup icon. It's for short wash (2 mins) and full wash cycle (after opening the pill drop chute) which takes 8 mins to complete. Instructions in your operator's manual.
Dec 04, 2008 | Espresso RMI La Cimbali Espresso Machine
Uniden Model EXP7900 How do I program button m1
One-Touch Dialing
Your phone is equipped with three .One-Touch Priority. keys for
instant dialing (m1, m2, and m3). You cannot store phone
numbers directly into m1, m2, andm3. They are only used
to dial phone numbers stored into memory locations 1, 2, and 3
on the keypad.
1. To instantly dial phone numbers stored in memory locations
1, 2, or 3, simply press m1, m2, or m3. (There is no need to
press talk, the phone will automatically dial.)
2. If no phone number was stored in memory locations 1, 2, or 3
on the keypad, pressing m1, m2, or m3 will do nothing.
I hope this helps.
Rollin CBs
Dean
Nov 04, 2008 | Uniden Cordless Phone
Cleanproblem
make sure you calculator says the number 0.
press the STO button. then press either 1,2, or 3. depending on what memory key is used.
so press the 2 button, and it should be clear.
Aug 20, 2008 | Texas Instruments TI-30XA Calculator
Binaton big button combo telephone
Press Speakerphone button
Press Set/Store
Enter the telephone number
Press Set/Store
Enter the memory number (M1, M2, M3 or 1-9)
Press Speakerphone button to hang up.
To use the memory feature,
For M1, M2 or M3, just pick up the phone and hit that button.
For memory number's 1-9, pick up the phone, press auto button, then enter number 1-9 for who you want to call.
Apr 16, 2008 | Lands Phones
Espresso RMI La Cimbali Espresso Machine Logo
356 people viewed this question
Top Espresso RMI Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Espresso RMI Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
