-   I have a similar problem where the dial behind the knob turns freely and the knob itself will not pull out to start the load. The knob turns freely and doesn't appear to be changing to a different cycle. Does anyone know how to fix this or the step in order to replace the knob?-   hokiefan1us
Dec 13, 2008
-   The knob appears to be in two pieces now. I can spin the bottom piece with my thumbs to get the mahine to cycle the way we need it. I can push/pull the knob which spins freely now. I want to replace the knob.
How does one remove the cycle knob? I tried pulling it but felt I was getting to the point of using excessive force and did not want to make things worse. -   fs11776
Nov 04, 2008
-   I have the same problem - start knob is unable to turn to different cycles. It just spins and doesn't engage. When I force the bottom part of the dial around, the machine will work. I want to replace the broken part, but after talking to GE parts, I'm not sure which part is going to fix the problem. Can you tell me if it's the timer (which, if I understood correctly has a shaft that attaches to the knob, a clip, the knob - or some other part? And how hard is it to replace?-   moyalynn
Dec 20, 2007
-   Same exact problem - cycle knob appears to be stripped and will not turn as it should when pulled out to set cycle. (One less than desirable workaround has been to ignore the button and press down on the inner ring, using a thumb on both sides. This will spin the dial to get it where you need it to be while the knob spins freely.)-   dangwasher
Try turning the dial v-e-r-y s-l-o-w-l-y to empty the tub. If that does not work, try to remove the dial and insert a broken toothpick in dial stem hole. Replace dial -- object is to get pressure on dial stem to turn the switch knob. You will need to purchase a new dial, obviously.
We have a GE WJRR4170 washer, with the same problem. At first I
thought I might have to unscrew the entire control panel just to
replace the knob. However, replacing it turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer
clip. If you pull out the knob (into the "start" position), you can
use a flathead screwdriver to push the clip out. The knob then will
slide easily off the metal stem. A GE replacement knob costs $9 or
$10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that
engages the dial has eight, flimsy plastic teeth. At any time, four of
these are supposed to engage four little slots in the dial. However,
the way the knob is designed, there will be a lot of wear and tear on
these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE WBSR3140DW Top Load Washer
agitator stopped working. cannot remove. need help on removal process/steps. top load type diagrams...
(More)
agitator stopped working. cannot remove. need help on removal process/steps. top load type diagrams would be helpful
