Question about Soyo 19" LCD Flat Panel Monitor
Monitor is fine but i need a base for it - Soyo 19" LCD Flat Panel Monitor
Which type of screws
Usually you rummage through your old screw dish/box and find one that fits. Threads for plastic - course. Threads for metal - fine. Check the length.
Aug 20, 2014 | Computers & Internet
Base not charging parent monitor
The rechargeable battery will need to be replaced.
Mar 20, 2012 | Angelcare Ac401 Deluxe Baby Movement Sound...
Fit in box
If it is into the original box and you still have all the packing then first step would usually be removal of the monitor base.
With CRT monitors the base usually pushes to the back and it is best done with the monitor upside down so that you can check for any locking tabs that may need to be pushed open.
Once the base is off you will find it easier to see on the packaging how it should fit..
Drop the base packing into the box first and then the monitor followed by the top packing.
there is usually a space for the base on the top packing.
Sep 15, 2009 | LG Computers & Internet
Attaching Samsung 2033 monitor to base
The solution is that you simply have to really force the monitor onto the base post. Thanks anyhow.
Jun 23, 2009 | Samsung 204T 20" LCD Monitor
I'm having a problem assembling my Samsung 2033 sw monitor. The directions are horrible and I don't want to snap the base.
I bought a Samsung 2033sw Monitor and I couldn't get the base attached to the monitor. When I returned it to Best Buy their "geek"
technicians discovered after opening another new monitor that
the spindle was attached to the monitor at the factory. But on
the monitor that I had problem with, the spindle was simply
put in the box along with the base plate. Best Buy solved the problem by disassembling the monitor itself and then installed the complete base assembly. You should return your monitor and asked the sales associate or manager to let you see another new monitor. The only thing you need to attached to the monitor is the round base plate.
Jun 17, 2009 | Computers & Internet
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
Power on/off
Hi, Try using another outlet.
Does your AC power cord have any indicator lights which is why you know the power cable works fine?
Base on your assessment, I would say the power supply board on the monitor needs to be replaced.
Thanks,
Mike H.
Nov 02, 2008 | Acer AL1717 17" LCD Monitor
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Soyo 19" LCD Flat Panel Monitor Logo
12 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
