Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Recently when i make a copy on my brother mfc 970mc, the copy has a line likely near 1/16 in wide running vertically on the copy. when I have an incoming fax, this line is not there. what to do ?? (when I reduce or enlarge making a copy that line is still a problem. I am fairly mechanical and handy with my hands...and...have a lot of tools. ps the line is approx centre of page PLEASE ADVISE my e mail. alecgillman@gmail.com
3 Suggested Answers
SOURCE: Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Posted on Oct 05, 2009
ryeisenman
  • 9 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
We have just one phone line that handels both incoming calls and faxes. Is there a setup proceder for faxes that are not on a dedicated line. When people call in they get a fax sound and it does not go to...
Hi there!
Mfc-970mc has a built-in message center that you can use. Once you activate this setting the person who's calling you willnot hear the fax tone again. On this setting you will receive faxes and voice calls on the same phone line/ phone number.
Please open the manual and check pages 79-95 to set up the built-in message center of this fax machine.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_870MC_MFC_970MC_EN_90.PDF
Please rate and hope this helps.
Mar 29, 2011 | Brother MFC-970MC Plain Paper Thermal Fax
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
Black Vertical line on copies using MFC-8660DN
Vertical lines mean it is being caused by one of the rollers within the printer. This is usually either the toner cartridge or the fuser assembly. I would try changing out the toner cartridge first even if it is new as sometimes they are DOA and they are much cheaper than the fuser assemblies. If that doesn't work, probably the fuser assembly.
Jun 05, 2009 | Brother MFC-8860DN Printer
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Vertical dark line on copies
That is comming from the scanner. If cleaning it well does not help, then it is one of the segments in the CCD assembly within the scanner that is the problem. That would requiring replacing tha scanner .
it could be a small scratch on that screen also.
Only thing you can try would be use some rubbing alcohol and a regular piece of 20 pound copy paper to clean the scanner glass/screen vigorously.
Mar 21, 2008 | Brother MFC-970MC Plain Paper Thermal Fax
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
