Question about Canon PIXMA MP210 Photo All-In-One Printer
Can't load paper properly
I recently purchased a cannon pixma 190 and cannot seem to load the paper properly because every time i try to print i get error 2 message which in the troubleshooting guide says paper out or paper does not feed. I reload the paper and press the color or black button but the paper does not feed and i get another error 2 message. I have read the instructions at least 20 times and thought that i knew what i was doing , but evidently i don't can someone help.....
yooperbud
  • 8637 Answers
SOURCE: cannon printer feed paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
yooperbud
  • 8637 Answers
SOURCE: my cannon pixma ip1600 has
Posted on Jan 28, 2009
  • 523 Answers
SOURCE: cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
Posted on Mar 11, 2009
xptareq2000
  • 1447 Answers
SOURCE: I have a new cannon pixma mp140, paper feed problem
it is problem paper prasser guide adjust or paper feed sensor is missing check it and service it
Posted on Sep 12, 2009
manishsh
  • 269 Answers
SOURCE: Where is Canon Pixma 190 serial number ?
here is the image where you find the serial number for your Canon Pixma 190 printer
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Posted on Mar 23, 2010
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
All in one Cannon Pixma MX860 inkjet
None go to : tp://www.usa.canon.com/consumer/controller
for support: Tech Support spacer.gif spacer.gif red_arrow_greybk.gif Frequently Asked Questions red_arrow_greybk.gif Support by E-mail red_arrow_greybk.gif Support by Phone
Jun 26, 2009 | Office Equipment & Supplies
Auto sheet feeder does not load paper straight causing it to jam.
Normal 0 Worth a try:
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print buttonapplying a slight amount of pressure on the Card Stock so it will feed throughthe printer. The reason for this, in some cases I have been able to clearthe paper track of debris that was deposited there over time. Worth atry. I have fixed a number of printers this way saving costlyrepairs. Bud
Jan 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP210 printer paper pulls to the right
Jan 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
44 people viewed this question
old marine
old marine
