Question about Frigidaire ATF6000ES Front Load Washer
Wheres the model number?
I have a front load frigidaire washer but bfore I can ask my question, I need to know where to find the model number. According to one solution I found I might need to clean the outlet filter. Where is that? Thanks.
  • 1 more comment
  • goblazer Dec 18, 2007
    Thanks - I found the part number FWT867GHS0
    I found the nodel number - it is FWT8676HS0. Where is the oulet filter. Thanks.
  • goblazer Dec 19, 2007
    I found it. I've cleaned it out and it still does not fast spin or drain. I'm going to replace the pump.
    Sergeant:
    Champion:
  • 262 Answers
Ok the model number is on a silver plate inside the door or on one side of the machine. the outlet filter in on the pump you have to take the front bottom cover off and you will see the pump it is hooked to the drain hose screw off the filter that is on the pump it is a slot turn counter clock wise and then pull out and clean
Posted on Dec 18, 2007
  • Bill Dozier Dec 19, 2007
    take the front cover off and its right in front of you the pump has a hose coming from the tub and one going to the drain hose facing you is a circle with a slit in it the filter is in there.on older models the filter is in the hose coming from the pump to the tub you have to fenigle it out of the hose from one end.
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
Frigidaire troubleshooting
Good morning friend, thank you for your post!
I understand that you are asking what the yellow light with a lock button on your Frigidaire washer means. Typically a lock symbol stands for control lock. I notice you did not provide your model number, if you comment back with your model number I would like to research to verify the information. Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. I look forward to your response.-Matt
Aug 17, 2014 | Washing Machines
Bleach dispenser
Hello friend, I appreciate your post!
I understand your having an issue with the bleach dispenser of your Frigidaire front load washer. I would like to ask a couple of additional questions to better assist you. Is it not dispensing bleach? If you add fabric softener does it do the same thing? Finally, what is your model number so I may be able to proceed further? Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame. Thank you for the post and I look forward to assisting you. -Matt
Jul 22, 2014 | Frigidaire GLTF1670A Front Load Washer
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Lights come on, door is closed, light load, but door will not lock so machine can begin filling with water. LFT7000ESO MODEL.
Good Afternoon Friend,
I understand that that you are having trouble with your Frigidaire washer, model# LFT7000ES0, and the door will not lock and begin filling with water. The model number you have provided, comes up as an invalid number. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If you do need more assistance, I will please ask for the model number of your washer. Typically you should be able to find this located inside your appliance around the edges where the door meets your washer. Hope this is helpful.
-Best Regards-
May 26, 2014 | Frigidaire ATF6000ES Front Load Washer
How to operate frigidaire washing machine, ill dont have a manual since i bought it 2nd hand ...
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
Where do you find the model # for a frigidaire washer? The tag under the lid has been removed.
Hello saguilar891 - Generally speaking, the model and serial numbers on Frigidaire front load washers are located on the upper front, as you open the door.
Nov 12, 2012 | Frigidaire GLTF2940ES Front Load Washer
Need to print manual on how to use my washer Affinity model.
This is the first one I found, check your complete model number and make sure it matches, if not the others are available in the Frigidaire website.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134850600een.pdf
Let me know if this helps,
Thank you
May 11, 2011 | Frigidaire Affinity ATF6000F Front Load...
BOUGHT A USED STACKABLE FRIDGIDAIRE AND NEED THE PLUG FOR IT, WHERE CAN I GET IT? WHERES THE MODEL NUMBER ITS A HEAVY DUTY CROWN SERIES
The Model number could be on the top of the machine or around the dryer door or by the washer lid. if your looking for a 220/240 volt 3 prong cord you should be able to get one at lows or home depot
Jan 09, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidare front load washer warranty
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Nov 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
210 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
