Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just spent $46 on ink. printed 14 pics and already ink is reading low on all colors
Anonymous
Level 3:
  • Master 344 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
Answers
344
Questions
Helped
104487
Points
1052
Sounds like you have a hpp printer......continue to use the ink until it wont print...odds are you purchased a defective cartridge....on a side note buy a kodak printer.....the ink is under $20 to replace...and kodak will back their printers more so than most other companies....
Printer says "incorrect alignment" and
Possible causes of the error you got can be that one of the ink cartridges is low or out of ink or the paper has already been printed on or is colored paper or the ink cartridge is defective.You need to
examine the paper the alignment page was printed on. Does the alignment page print correctly?You need to perform an print cartridge cleaning procedure and Try to align the page again.
Yellow ink isnt printing even after deep clean and test page print
Maybe the ink inside the catridge already low or empty, sometimes each color ink will empty at different time, depend on usage. Fill only the yellow ink and try to print again.
Hope this help and RATE please !
Hey guys! My ESP7 is using an enormous amount of colored ink! I'm on my third cartridge and I haven't printed 20 5x7 pics. Or the 'low colored ink alert' is not properly functioning. Is there any way I...
Page yields are estimates and how many pages (or photos) you get out of a cartridge depends on the percent coverage for each color. In general page yields are based on 5% coverage, which translates to double spaced text. Printing photos uses a LOT of ink and it seems like there isn't much ink in these cartridges to start with. I would not expect that the ink alert is malfunctioning. I own a Cartridge World ink refilling store and I would be happy to give you a recommendation on a printer that would better suit your needs.
1helpful
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
ESP9 color prints begin coming out purple like
Use only original ink cartriges, the non original has ink normaly is not for you printer, and you wast your money and damage the printer print-head
V350 printer - color ink won't print in color.
make sure that you have purchased the right kind of cartridge and that it is securely fashioned the the printer holster!
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
6helpful
2answers
Can't print without black Ink
From HP's website:
The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges.
Try this::
Leave the empty cartidge in and go to print, select the printer, click on preferences, then the paper/Quality tab. there select color and best. This way you wil be able to print your document.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nagging low ink message IP4000
Put in a set of new color cartridges and then make sure in the printer settings it is set to Black & White printing only.
Hope this helps
Thanks for reading!
k24674
ADMIN Andrew
ADMIN Andrew
