Question about Samsung HCL4715W 47" Rear Projection Television
My samsung hcl4751w converg control is not functioning , the blue tube convereg control functions verticly & horroztaly, the green only goes vert up & dwn, the red will not move . what dod i have to change to have them work properly
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 27, 2009
Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
To process and save the adjustment made, follow the steps below;
  1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  2. Enter the menu on your TV. Use the remote control and bring up the menu.
  3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  5. Press "Enter." A crosshair pattern will appear on your screen.
  6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  9. Repeat these steps for all colors.
Take care
Jul 06, 2010 | Televison & Video
Red vert lines will not convergenge(sides) blue and green o.k.
your convergence output amps are done...
you have to do repair on the convergence output circuit, and inspect
the power supply for any damages.
Jan 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a Samsung HC-P4752W and see yellow and bllue halos.
Have you tried to use the convergence function on the TV? If that has not fixed this issue then you have bad convergence IC chips. These chips are microprocessors that align the blue and red tubes with the green (which is stationary). This converges the three tubes to create the image that you see. Failure of these chips (usually from heat over time) is a common problem with projection  TVs. The chips are not very expensive; from $35-60 for the pair. Replacing them involves some tedious desoldering of the old ones and soldering in the new ones. If you have some experience with electronics and soldering it is not hard. Shops will charge $300 and up for this repair. If you want to do it your self post a comment bnack here and I can assist you further.
Dec 05, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence issue... I tried to manually fix it through the menu option without any luck. The convergence does curve at the top and bottom of the screen.
It seems the solder is broken in Vertical Convergence Amplifiers or it is damage internally. This model has 2 Conv. Amps: 1 for Horizontal (Red, Green and Blue) and 1 for Vertical Convergence output (Red, Green and Blue), if the convergence does curve at the top and bottom, it is because Vertical Converegence output is no good. The Conv. Amp. costs around 20 dlls. Thats why you can not fix it with the Menu option. Good luck!
Nov 13, 2009 | Philips 60PP9202 60" Rear Projection...
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Red Green Blue horizontal line at top of screen
Since both were replaced at one time, you now can't limit the problem properly. Should have been done one at a time.
Your vert height may be too short, causing you to be seeing things that should be off screen.
This can be remedied in the service mode.
Mr Bob
Feb 06, 2008 | Mitsubishi WS-65411 65" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Update and a few questions (Convergence Problems - VS-55601 55 in Projection)
yes, they go bad interment because they have a large current go thru them and they generate heat, they are mounted on a heat sink with white silicone to help disapate heat. replace both not just one, try MCM Electronics get heat sink compound also
Oct 06, 2006 | Mitsubishi VS-55601 55" Rear Projection...
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
322 people viewed this question
Jerry Greenberg
Jerry Greenberg
