Question about HP Photosmart C6180 All-In-One InkJet Printer
I have an ink system failure. I changed all of
I have an ink system failure. I changed all of the ink cartridges, turned the printer off, then unplugged it for a few minutes, then plugged it back in, turned it on and I still have the error number: Oxc18a0206.
  • 181 Answers
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Posted on Sep 28, 2009
  • 59 Answers
  • 21 Answers
To resolve this issue you need to contact HP as they have few confidential steps which I do not have and only a HP Customer support can provide you that.
I regret to say you this but I do not have them.
Yours,
Mujahid498
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
Printer is showing ink system failure. what does this mean? how can it be fixed?do we just need to replace all of the ink cartridges? help!
Ink system failure indicated that ink delivery mechanism of the printer is experiencing problem. We need to do below resets for this printer to fix this issue.
Solution 1:
  • Press the On button to turn of the printer.
  • Unplug the power cord from the back of the printer and from wall outlet or surge protector.
  • Removed all the ink cartridges
  • Wait for 2 minutes
  • Connect the power cord and turn the printer On.
  • Install the ink cartridges
(Please go to solution 2 if the problem is not resolved)
Solution 2:
  • Remove all the ink cartridges.
  • While the printer is ON, unplug the power cord from the back of the printer.
  • Press and hold OK and Cancel button, while holding these buttons connect the power cord.
  • Release the button after 20 seconds.
  • Turn on the printer if it goes off and install the cartridges.
Regards
Riztech
Mar 04, 2010 | HP Photosmart 3210 Printer
I keep getting ink system failure on my d7160 printer
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then reinstall the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 31, 2010 | HP Photosmart D7160 InkJet Printer
HP c6150 all in one error message Oxc19acff Ink System Failure. Replaced Yellow ink cartridge an still receive error.
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the machine, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, turn the machine on using the power button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime ink through the system. There are instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Jan 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
Ink system failure. How do I reset a hp 8250 printer?
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the power button to turn on the printer, wait for the printer to prompt that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error you may need to re-prime the ink cartridges. There is a good explanation of how to do this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Nov 15, 2009 | HP - HP Photosmart 8250 printer
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp ink system failure
Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
Wait two minutes.
Sep 14, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
288 people viewed this question
Seeker5211
Seeker5211
