Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Mower will not turn over
I have a Yard Machines 158cc push mower which will not start. It will turn over only to shut off seconds later. I have cleaned all components and replaced the spark plugs. I am at a loss for what to do next. Please HELP!
  • 718 Answers
Are you sure there is no water in gas tank, are you sure you get spark with new plug? component cleaned include carb and its components inside and out? If it turns over and does not stay running maybe first bet, you have water in the gas, second there is some kind of blockage within the carb probably so small you would not believe that it could be a problem.
If you disconnect the hose from the carb and empty some gas into a clear jar of some sort you can see if you have water in the gas. You will see two levels in the jar if contaminated, a yellowish gasoline level and a clear bubbly level which would be be water. Gas separated by something else means your mower will not start! Should be all yellowish in color.
Posted on Sep 30, 2009
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Engine wont start after shutting off to refuel
You most likely have a piece of debris stuck between the needle and the seat inside the carburetor.
May 11, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I already cleaned out the carb. the mower will start then just stop a few seconds later
still sounds like not getting fuel ,did you soak the carb in something overnite,this is what I do ,sometimes just a spray out wont help.how old is mower?
Apr 22, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
158cc yard machine, starts then dies.
Your fuel tank and carb need to be removed, both cleaned and replace pump diaphragm between carb and tank. If you want to do it yourself, let me know and I;ll tell you how. Not a difficult job. Dwain
May 26, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
456 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
