Question about Garden
How do you remove the primer bulb on a Briggs and Stratton model 10a902 engine
    Scholar:
  • 110 Answers
On each side of the primer 'casing', there are apatures in the outer. Squeeze these inwards, and the retaining ring and primer rubber can be pulled out.
Posted on Sep 27, 2009
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
I have a Briggs and Stratton/Bolens 20" lawn mower which needs a primer button. Where can I get that part(s)? Thanks
It looks like the number you are giving are from the mower deck, and would work great for anything but the engine. On a flat head engine above the spark plug on the tin air shroud there will be some more number and they go to the Briggs and stratton engine you have.On a overhead valve engine you should look on the valve cover. There will be model, serial , and spec numbers, all three would be great and would make it easy to look up the primer bulb and post a link to it for you.
Mar 25, 2016 | Garden
I have a 22 inch self propelled recycler that will idle for hours,but as soon as you engage the self propel and start mowing it stops after 5 minutes.
This sounds like fuel starvation. This is usually caused by debris in the fuel float bowl or a dirty fuel filter (if used). Remove the fuel float bowl and clean out the debris. With the bowl removed use a spray paint can lid as a catch pan and check fuel flow. With the float down it should fill the spray paint can lid in about 10 seconds. If you do not have this much fuel flow you need to inspect the tank outlet port, fuel lines and filter (if used).
The 20029 & 20099 models came with either a Briggs & Stratton or Kohler Courage XT7 engine. I need to know what engine you have to provide any diagrams on what to check or clean. A n engine model number would be even better. (Please!) Since the post is labeled with the 20099 model I will cite that as a reference. This SERVICE manual should help you with repairs:
http://www.kohlerengines.com/onlinecatalog/pdf/tp2601_308.pdf
See page 27 of the manual for fuel filter location. (Optional if used) AN exploded view is on page 31.
If you have the primer bulb model see page 24 and note the ondition of the primer bulb and primer bulb hose. Any hole in the primer bulb or cracks in the primer bulb hose can also cause this symptom.
If you have the Briggs and Stratton engine (Model 20029) I need the engine number to get you the correct manual data please. Otherwise...this should help you resolve the problem.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
How do you remove the primer bulb on a model 10a902 Briggs and Stratton mower engine?
Look at the outside of the plastic housing where the primer bulb is inserted, you will see an open area where there are 2 tabs, one on each side, using a small screwdriver, push these tabs inward to release them and slide the whole thing out of the hole including the primer bulb. The new primer bulb normally comes with a new mounting ring if you purchase it from a lawnmower dealer
Sep 27, 2009 | Briggs & Stratton Garden
I too need to replace the primer bulb but do not know how.
U need a pick with a hook on the end--around outside of bulb is a ring that has to be removed-clean area and instal new bulb and ring--make sure ring in pushed tight against bulb
Jun 08, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
May 30, 2009 | Craftsman Garden
Need to replace primer bulb on a briggs & stratton lawn mower
pull the bulb and retaing ring any way you can. don't try ti save them. you get a new retaing ring with the bulb. put the new bulb in then work the retaing ring in with a screw driver,clean everything behind the bulb before you put the new on in.
Apr 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
321 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
