Question about Drills
Jammed 2 speed switch
Ryobi 18v (ONE+) - 2 speed cordless drill/driver
I was given the above and I switched it from fast to slow speed (2 to 1) and now i can't get it back to No 2 speed position?
Thank you
    Problem Solver:
  • 14 Answers
Sometimes you have to rotate or just try to move chuck a little to align gears then try to change
Posted on Nov 13, 2009
Variable speed not working, the trigger is either full on or off. speed switch 1 or 2 works
Replace the switch because a power mosfet inside is defect
650583-6 look for that switch partnumber also ferify it because this is for the model in the netherlands but most time its the same by Makita and its not to expensive will succeed to replace succes. but be careful when pulling out the wires using a thin watch screwdriver to push the unlock holes next to the connector contacts.
Nov 01, 2015 | Dewalt Makita Bhp452 18v Cordless 1/2"...
What is the best way to store the new ryobi 18v battery
Is your ryobi 18V battery is a Li-ion battery? if so you can store it with 40% power and keep it clean, cool, and dry. Then every 1-2 month to charge and discharge the battery for once time.
More battery tips or batteries and chargers for cordless tool you can come here:
Cordless Drill Batteries Replacement Cordless Power Tool Batteries...
Nov 02, 2014 | Drills
Why does ryobi 18V cordless not charge
Please check the LED status of your charger. If both of the charger'sLED flashing, but it can charge a good battery. Than the battery is defective, you may replace a new Ryobi P206 Battery http://www.batteryshops.co.uk/tags_products/ryobi-p206-12-18v-2-speed-drill-driver-battery_6854.html
May 11, 2014 | Ryobi 18v Cordless Drill - P206 18 Volt V
Ryobi 18v Lithium cordless impact drill chuck comes loose while drilling
Tighten the screw inside were the drill bits or attachments go this is a reverse threaded screw try using lock tight also
Aug 31, 2013 | Ryobi 18v Variable Speed Impact Driver...
Why does my Ryobi 18v drill not hold charge?
chances are that your batteries are shot. If you do some searching in your local city, see if there is company that will rebuild battery packs for your drill. The packs are around 1/2 to 2/3 the cost of a new pack and they will have better batteries in them. The manufacturer does not put the best grade of batteries in their equipment. So a rebuild is stronger and will last longer.
Feb 20, 2011 | Ryobi 18v 1/2" Cordless Drill - P204 - 18...
Ryobi 18v battery drill/driver on/off switch faulty stuck on go
if the trigger won't pop out it will need to be changed. tool parts direct or ereplacement parts are good to find parts. be very careful if or when you open the case. when the guts come out they go back one way or the case won't close.
Aug 28, 2010 | Ryobi 18v Variable Speed Impact Driver...
18 v Driver. Need trigger switch
Google ryobi stores. I'm in az and they have them here. Or ryobi repair and your location. I went to the dewalt replacement shop got a trigger for my angle grinder for under 2 dollars.
Jun 15, 2010 | Ryobi 18v Variable Speed Impact Driver...
Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for high torque applications. Auxiliary handle with metal depth stop rod. Has an overmold grip handle for added comfort. A Mag Tray holds screws, small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.' heavy duty keyless chuck for quick and easy bit changes. Removable 2 position level for convenience and accuracy
Apr 19, 2010 | Ryobi 18v Variable Speed Impact Driver...
Dewalt 18v drill dc988 type requires switch
Here is a link for a parts diagram for your model. It has the proper part number that you will need.
Hope this helps.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/dewalt/DC988KA_TYPE_1
Sep 07, 2009 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drills Logo
56 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
