Question about Philips LX3750W System
My phillips lx3750w dvd player is showing no disc.
I have tried the head cleaner this did not work. Any other suggestions?
  • 1153 Answers
SOURCE: Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Posted on Sep 05, 2007
Shuttle83
  • 1139 Answers
SOURCE: phillips dvd player
OK lets start off by getting rid of the CD lens cleaner (CD cleaners do more damage then good). Now first we need to clean that lens with a DVD lens clearner (finer cleaning surface). Try to run the DVD cleaning disk twicw (no more) and try to play a DVD. If this does not work. You may have to test the laser power. get a schematic for the DVD that you have, and use it to let you know the specific power measurement of the power, This is done by using a laser power meter, you may not have one, so this becomes a moot point, but on the off chance that you do, use the laser power meter to measure the laser energy and make sure it is to specs as seen on the schematic. If you do not have a laser power meter., well I hate to tell you this but you may have to get a new unit. See the problem is the process of fixing this problem is simple if you have the right equipment, but if you don't you are at a disadvantage.
Posted on Sep 11, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: no disc
Run a dvd cleaner on the player
Posted on Feb 19, 2008
Beignorant
  • 51 Answers
SOURCE: Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Posted on Apr 02, 2009
  • 5 Answers
SOURCE: Philips PET710 DVD player shows 'no disc' when disc inserted
The safest way , this may sound really stupid but has always worked for me is give it a slightly rough slam on its bottom and it will work , dont judge this badly for it actually wotrks
Posted on Feb 16, 2010
No disc message
1 - Try a different disc.
Either works, or not.
If works, problem original non-playng disc.
If not working, problem is player (or another faulty disc).
2. If player is problem:
Try using a 'head-cleaner' disc (from store).
These usually play whilst cleaning.
If no play - problem is 'read head' in player.
If it plays, then try ( a known good - works in another machine), disc.
3. If 'read head' is faulty, you need a techy to replace, or throw it away, buy a new one (more likely).
Rafe
'Live long and prosper'
Sep 07, 2013 | Craig CVD327 DVD Player
My dvd player phillips dvp3040/37 always shows "no disc". please help me.
Get a dvd cleaner disc. Or take it apart and clean it. Sounds like a dirty lens.
Mar 20, 2011 | Philips DVP5140 DVD Player
Want to play region 3 dvd on region 2 Phillips lx3750w player and need the unlocking process please. Thanks
  1. Turn on the player (without a disc inserted)
  2. Press PLAY
  3. Press 159 023 793 90
  4. Press PLAY
  5. Confirmation should be displayed
  6. Turn the player off
Jan 08, 2011 | Philips LX3750W System
Says loading disc then no disc pops up and it just won't play. Tried the phillips lense cleaner still does same message (loading the no disc)
The reason the player keeps loading and showing no disc is simply because the lens of the player is weak.
To fix this,
  1. Open the cover of the player with the appropriate screwdriver,
  2. Open the disc tray,you will see the lens, like a crystal or diamond like object,
  3. Replace the lens by removing it with the mechanism that supports it and fixing the new lens,
  4. Test it with a DVD disc.
  5. Cover the player back.
Take care
Jun 21, 2010 | Televison & Video
Displays No Disc when a disc is inserted
Sounds like the player is dirty. Try getting a cd player cleaner. clean it and try again.
May 26, 2009 | Philips Televison & Video
Every disc is a "Bad Disc".
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | Recoton Advent Advent DVD-8200 DVD Player
Phillips 3960 dvd player shows no disk
i have had the same problems with some of my dvd players. some of the cheaper ones just wear out with alot of use ... ie: my daughters in her room but i have found using those cd/dvd head cleaners (the disc that you buy for like 10 bucks) work wonders.. run that a couple times and you should be having alot better luck with your dvd player
Feb 14, 2009 | Televison & Video
No disc
Dec 30, 2007 | Philips LX3750W System
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Philips LX3750W System Logo
81 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
