Question about Refrigerators
Won't cool My refrigerator is basically brand new and only used twice in the last 8 months. When I turn it on it will only display room temperature and will not cool to the set temp.
  • 525 Answers
Yes , yes , your refrigerator need a breathing space. unplug it , move it to 1 foot away from the wall ( it must stay to this distance for ever); wait 15 mins and plug again. Yes my dear enjoy , how God gave us skills to help people.
Don't forget to vote for me if it works .
Posted on Sep 27, 2009
The temperature displayed on the front of our fridge is incorrect, How do I fix this?
possible that the rear of the fridge needs space for the condenser to get air to cool
Oct 24, 2015 | Refrigerators
Refrigerator problem
Hello , this is JK. I understand that you are experiencing a concern with the refrigerator cooling. Have you cleaned the condenser in the last 4-6 months? Gently place your hand on the static condenser coils on the back of the refrigerator. Are the coils room temperature or warm? Room temperature air usually means that the compressor or sealed system is not removing the heat from the cabinet. This could mean that the there is a sealed system leak, overloaded relay or a faulty compressor. Warm air means that the compressor is operating correctly and the sealed system is removing the heat from the cabinet. Are the controls set to the right setting? If you see that they are set correctly, consider activating the defrost. The compressor will shut off, wait five minutes and look through the grille in the freezer for a red glow of the defrost heater. If you do not see a red glow you may need to reach out to a professional technician. Hope this helps!
Apr 18, 2014 | Frigidaire FRT15B3A Top Freezer...
Display showing twice the room temperature boiler not igniting
If you need heat turn breaker off to heater. Put a jumper in the tstat on a and b. Turn breaker on. This should bring on the heat by bypassing the tstat. You will have to turn the heat off by the breaker as long as jumper is in. Always turn power off if messing with wires.
Jul 01, 2017 | Honeywell Programmable Thermostat Heater
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
I just bought a brand new Frigidaire 4.6 cu beverage center FFBC46F5LS, brought it home and plugged it in. Ran it overnight and still at room temperature. I can hear the motor is on, light is on. not...
Being it is brand new you should contact Frigidaire about getting it repaired or replaced under warranty.
Frigidaire 1 (800) 374-4432
Monday - Sunday
8:00 am - 8:00 pm (EST)
Aug 03, 2011 | Frigidaire PLKU1267DS Stainless Steel...
Lamp bulb indicator is red and unit will not light up
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Also, check and clean the air filters.
Jul 17, 2010 | Optoma HD65 DLP Projector
Our brand new kitchen aid oven will blow hot air for up to a half hour after it has been turned off. This seems unusually long- what is the expected time of cooling off?
That depends on the ambient temperature in the room..if your room is fairly warm you can expect it to take longer then if the room is cool...
I would say though that 1/2 hour is pretty normal...it is good to get the unit cooled down, the less time it is warm the longer it will last... heat kills ovens...even though they are made to take heat...
heatman101
Apr 24, 2010 | Ovens
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Maximizing life of external HD
keeping hard drives running will cost more on electric and heat generated from drives as I've found out on of my 160gig sata drives burnt out because I was using pc 24hrs aday and night if I had put a cooler on the bottom it would have lasted 5 years but I only lasted 8 months you can give your hard drives 2 twice or even 5 times life span if kept at room temperature listen to you own advice it's your data and hard drives do what you wish I'm only her for advive you can tak itor leave it
Oct 01, 2006 | LaCie Design by F. A. Porsche 160 GB Hard...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
