Question about Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator
Top freezer of my refrigerator has a layer of ice on the bottom
  • Whirlpool Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratortop freezer of my refrigerator has a layer of ice - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
ICE FORMS IN FREEZER BOTTOM,
Keep the bottom of your freezer free from ice. ... The water from the melted ice and frost drains through a short tube and into a pan beneath the refrigerator, where it evaporates. Should the drain line become clogged, the water has nowhere to go and it freezes, forming a layer of ice in the bottom of your freezer.
How to Fix an Iced Freezer Bottom ' Home Guides ' SF Gate
homeguides.sfgate.com/fix-iced-freezer-bottom-42777.html ICE FORMS IN FREEZER BOTTOM Google Search
Oct 23, 2017 | Refrigerators
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Layer of ice formed on the bottom of freezer and a layer of water with no obvious source has formed on the top shelf on the right side.
That is an easy one. Instead of the defrost liquid draining down the drain hole it is blocked and a slab of ice is forming. You must thaw out the ice box and clear the drain hole. Another thing that could cause this slab of ice could be a leaky ice maker water valve or a faulty ice maker pumping in too much liquid into the ice mold.
Jan 15, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Sub zero ice cubes are turning out badly
hold in the alarm button for 10 sec and it will reset...let me know
Jun 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
