Question about Briggs & Stratton Garden
How do you remove the primer bulb on a model 10a902 Briggs and Stratton mower engine?
  • 389 Answers
Look at the outside of the plastic housing where the primer bulb is inserted, you will see an open area where there are 2 tabs, one on each side, using a small screwdriver, push these tabs inward to release them and slide the whole thing out of the hole including the primer bulb. The new primer bulb normally comes with a new mounting ring if you purchase it from a lawnmower dealer
Posted on Oct 01, 2009
How to replace lawnmower primer bulb on honda GCV160 engine?
Leo, Did not find your exact model, procedures are usually basically the same. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb Replacement Briggs Stratton Engines
HOW TO Replace Lawnmower Primer Bulb
How to Replace Primer Bulb
May 23, 2016 | Honda Garden
I have a Briggs and Stratton/Bolens 20" lawn mower which needs a primer button. Where can I get that part(s)? Thanks
It looks like the number you are giving are from the mower deck, and would work great for anything but the engine. On a flat head engine above the spark plug on the tin air shroud there will be some more number and they go to the Briggs and stratton engine you have.On a overhead valve engine you should look on the valve cover. There will be model, serial , and spec numbers, all three would be great and would make it easy to look up the primer bulb and post a link to it for you.
Mar 25, 2016 | Garden
I have a 22 inch self propelled recycler that will idle for hours,but as soon as you engage the self propel and start mowing it stops after 5 minutes.
This sounds like fuel starvation. This is usually caused by debris in the fuel float bowl or a dirty fuel filter (if used). Remove the fuel float bowl and clean out the debris. With the bowl removed use a spray paint can lid as a catch pan and check fuel flow. With the float down it should fill the spray paint can lid in about 10 seconds. If you do not have this much fuel flow you need to inspect the tank outlet port, fuel lines and filter (if used).
The 20029 & 20099 models came with either a Briggs & Stratton or Kohler Courage XT7 engine. I need to know what engine you have to provide any diagrams on what to check or clean. A n engine model number would be even better. (Please!) Since the post is labeled with the 20099 model I will cite that as a reference. This SERVICE manual should help you with repairs:
http://www.kohlerengines.com/onlinecatalog/pdf/tp2601_308.pdf
See page 27 of the manual for fuel filter location. (Optional if used) AN exploded view is on page 31.
If you have the primer bulb model see page 24 and note the ondition of the primer bulb and primer bulb hose. Any hole in the primer bulb or cracks in the primer bulb hose can also cause this symptom.
If you have the Briggs and Stratton engine (Model 20029) I need the engine number to get you the correct manual data please. Otherwise...this should help you resolve the problem.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Need repair manual for briggs and stratton 4.5 hp on bolen lawn mower model 11a-414e765
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Kelly.
May 10, 2011 | Briggs & Stratton Briggs Stratton...
The 'primer' doesn't work on my mower's Briggs & Stratton engine. Is there an easy fix?
You can try pumping primer bulb 10-15 times instead of 3 or 4 that manual probably suggests. We have a craftsman 22 inch cut push mower with a 3.5 H.P. BRIGGS &STRATTON engine and if you don't prime it at least a dozen times it will not start. It is possible that you have a small hole in your primer bulb in which case it can't create suction to bring gas to carburator. If this is the problem you can purchase a new bulb and seal at most larger SEARS stores or service centers.I would guess that if you have manual for mower you can get part number and phone number to get new parts .Hope this helps. Thanks
Nov 08, 2010 | Garden
How do you remove the primer bulb on a Briggs and Stratton model 10a902 engine
On each side of the primer 'casing', there are apatures in the outer. Squeeze these inwards, and the retaining ring and primer rubber can be pulled out.
Sep 27, 2009 | Garden
7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
May 30, 2009 | Craftsman Garden
Garden Logo
250 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
