Question about LG DU-62SY20D 62" Rear Projection HDTV
LG 156cm rear projection tv
TV turns on fine but after a while the screen turns red. Screen comes good again after turning off for a while.
SOURCE: Red lines on Sony KP51HW40 Rear projection TV
This should be a very simple fix. The lines on your screen are call retrace lines. Basically you need to open the TV and the job is about 15 minutes to solve the issue with arched lines, either blue, greed, or red. There is a great how-to guide here:
Posted on Jul 02, 2007
SOURCE: access service menu lg rear projection tv
Hold the menu button on the remote and the menu button on the tv down simultaneously for 5 seconds.
Posted on Aug 10, 2008
  • 2920 Answers
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
youll need to have the tv converged...the red being out of line says that
Posted on Nov 05, 2008
  • 6 Answers
Before you break down and have the tube repaired, it could be a faulty or mis-adjusted screen setting. These projection TV's have three individual CRT tubes. Each tube has a FOCUS and SCREEN adjustment on a block inside the TV. I have the 57" model of the same series of TV's and just had to do some work on it. If you remove the front panel and the small wooden panel behind that, you should see a block with 6 screw adjustments. On my TV the set on the right was for the red tube. The top screw adjusts focus and the bottom adjusts screen. Focus (as the name implies) makes the screen go in and out of focus. If your TV isn't blurry then don't touch the top knob. The bottom knob is SCREEN. This knob adjusts the brightness (power) of the tube. If this knob is turned up too high, red lines will start to develop across the screen. At first, they'll only be visible when the screen is black, but if you keep turning it up they'll become very visible. If you turn it up even higher the whole screen will become red. Running it at full power (the whole screen being red) will cause an electronic lockdown and shut off the TV (at least it did with the blue tube, I was playing with the knobs and accidentally made it turn all blue then click off. I waited a few minutes, turned the knob down, then turned the TV back on and all was fine again). What you need to do is simply turn down the bottom right knob until the red lines go away. Put the TV on a blank screen (all black, just having it on an unused video input works great) and then slowly turn down the lower right knob (red screen knob) until the lines go away. Then put the TV on a picture to make sure the red is still visible. Finally, turn off the TV and turn it back on and use it for a while (don't put it back together yet, but make sure the front panel buttons and LED's are connected). I had a problem where the TV gave me an error code 5 (AKB error, shown by the Standby light flashing in sets of 5). After some reading and experimenting I found out that it was giving me this because I had set the red TOO low. I turned it up until the lines showed up and then turned it just slightly until the lines just vanished (but no further down) and then reset the TV by going to the system menu (Display, 5, Channel +, POWER while the TV is off) and then pressing 8 then Enter (Factory Reset). If you simply follow my advice (don't turn the knob down any further than necessary, just to the point that the lines don't show) then you shouldn't get the error at all.
Posted on Jun 02, 2009
  • 5138 Answers
SOURCE: How to reset the lamp timer count on a LG rear projection TV
Where you got new lamp, should have information on how to reset timer for New Lamp.If i can find my information on resetting timer i will post it for you.
Posted on Jun 15, 2009
  • 5138 Answers
SOURCE: LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Posted on Aug 15, 2009
0 characters
1 Points
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Jul 22, 2009 | LG RU-52SZ30 52" Rear Projection...
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
May 28, 2009 | Sony KP-51HW40 51" Rear Projection...
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
LG DU-62SY20D 62" Rear Projection HDTV Logo
143 people viewed this question
Top LG Projection Televisions Experts
Steven Wander
Steven Wander
Lawrence Oravetz
Are you a LG Projection Television Expert? Answer questions, earn points and help others
