Photography Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I am a high school student in Photo 2. I just got a Canon EOS 3 and i can not locate my self timer. Please help.
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Sep 27, 2009
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3072768
Points
27242
Hi uour manual tells you how to set self timer on page 87. If you do not have the manual here it is on link below. Click link and what for manual to load it mignt take a couple of mins.
http://www3.canon.de/images/pro/fot/slr/geh/file/EOS_3_eng_toc.pdf
Good Luck
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
I was taking a photo with the self-timer, and now it's stuck on self-timer. Except it won't take photos or anything. It's just stuck.
Maybe you need to bring it back for servicing as the shutter might be jammed. I guess it will still be able to take videos without any problems right?
Programming in TI-84 Plus? I'm a High School student?
There is nothing wrong with your English. The problem with your request is that the program you are talking about is NO program at all, but a collection of formulas that may serve as a cheat sheet. If your teacher wanted you to make this program he would have shown you the steps to key in. Besides it would be a lot more efficient to just write these formulas on the board. Sorry, there will be no help from me.
Your formulas 2 and 3 are useless, and formulas 7 and for the real solutions of a quadratic equation are wrong. The right member should be multiplied by 1/a.
How about trying to learn your formulas by heart? It is good for your memory and you will avoid being caught cheating.
I have a Canon EOS 400D and I lost the manual, I need to set the timer so everyone can get into the shot. What button do I use, I need a really simple explanation please
You can download the manual from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/digital_rebel_xti#BrochuresAndManuals
The self-timer is on page 49.
I have a Canon 40D. When I press the shutter button, it has about a 5 second delay before taking the photo, on all modes. Help!!
You may have set the self timer, which is ordinarily used when you want to get into the picture yourself.
9helpful
Canon EOS 5D Mark II whrer is the selftimer botton
Self timer function is mentioned on page-86 of manual.
Below image is part of user manual that will help you to turn on self timer.
Thanks.
1helpful
EOS Rebal XS stuck on self-timer
1)Press the left arrow key (which is located to the left of 'SET' button at the back of camera). It has clock pictogramm near it.
2)Use left/right arrow key to select square pictogramm to set drive mode to single shooting.
3)Press SET button to confirm your choice.
1helpful
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
2helpful
How do I use the self timer on my PowerShot A570 IS camera? Please help...
Press the Center Button
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800, 1600) - see below
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) - see below
  • Drive (Single-shot, continuous, 2 or 10 sec self-timer, custom self-timer)
  • My Colors (Off, vivid, neutral, sepia, black & white, custom color) - see below
  • Flash compensation (-2EV to +2EV in 1/3EV increments) + flash output (1/3, 2/3, full) - this last item is only available in manual mode
  • Metering mode (Evaluative, center-weighted, spot)
  • Compression (see chart later in review)
  • Resolution (see chart later in review)
The Third Option is Having Self Timer ..... Check
Canon 40d self timer
The self timer icon should show up on the LCD panel, on top of the camera on the right side.
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
