Question about Cameras
Will not allow me to insert a tape. also when you
Will not allow me to insert a tape. also when you turn it on it plays constantly and will not stop. I have a GR-D91U JVC
  • spydercat2 Sep 28, 2009
    There is no tape in the camera. It is stuck in play mode and will not stop unless you remove the power source.
  • David Shaub May 11, 2010
    If it plays constantly when you turn it on, there is already a tape in it. You won't be able to insert a tape, until you eject the tape that's already in it.
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
Tip
How to Safely Clean a Tape Video Head
If you are not getting video from a VCR, 8MM camcorder, or Digital Video recorder camcorder but get audio, do the following: <br /> 1. Use a brand new tape - right out of the package and insert it into the drive. <br /> 2. Perform a record on the tape - set it to do a RECORD (not playback). <br /> 3. Allow it to complete through the entire tape without stopping. <br /> 4. Upon completion - allow it to rewind. <br /> 5. Insert a known good prerecorded tape and play - observe the image. If it's good, then the head was just dirty and is now clean. <br /> You may perform the above as often as necessary without any damage to the device.
on Dec 13, 2010 | Televison & Video
I constantly get this message-"re-insert
No. The timing cam is misaligned. The carriage is suppose to accept the tape, and when you close the door, it pulls the tape from the carriage towards the head and drive the take-up reel to the supply reel as the head reads or plays back the tape. If the timing cam is misaligned, it will not accept the tape and thus you get the error message.
Nov 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
"Please Re-Insert Tape"!!!
stop bying sony camcorders, I had same problem and its was my second sony camcorder that failed to function properly after just one year (just after waranty expierd) the first I took to shop to repare **** after two weeks it was broken again, this while I diden't even realy used it; my very first camcorder: a canon, functioned more than 6 years and if I wanted I could still repare it **** it's analog. so go Canon, even sanyo is better these days than a f#^îng sony
Oct 22, 2008 | Sony Handycam DCR-TRV265E Digital...
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Cameras Logo
42 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
